Toymods » Tech & Conversions » bolt together roll cage?
chubbylover53
bolt together roll cage? Wed, 13 October 2004 23:29 Go to next message
does anyone know of a fully bolt together roll cage out on the market. I want to design my own for a project but i want to know if someone has already made one. I know there are roll cages out there witch are all welded up and just need to be bolted to the floor but i want to design one which comes in different parts and bolts together kind of like the polls of a tent.
cheers Smile
StuC
Re: bolt together roll cage? Thu, 14 October 2004 01:09 Go to previous messageGo to next message
No offence but i thought the idea of a roll cage was so it would be strong and withstand massive blows. Wouldt a bolt together cage just fall apart, no matter what size bolts yours using? I think there are some available tho, but as far as i know they're purely for looks. If you want a custom cage, spend the extra and get one made up, even get one and modify it.
GL with the search
stumpy
perth WA
Re: bolt together roll cage? Thu, 14 October 2004 01:42 Go to previous messageGo to next message
Try Bond Rollbars.
cwhelan
Adelaide, Semaphore
Re: bolt together roll cage? Thu, 14 October 2004 02:14 Go to previous messageGo to next message
Just a query, for all of you that are thinking about getting one made, or even making one yourself.. What schedule pipe is to be used? Sched/40 or shed/80, also must it be seamless?
Are there design lines that must be strictly adhered to, and if so does anyone have the specs on what they should comply to and also design features.
demuire
Ipswich
Re: bolt together roll cage? Thu, 14 October 2004 03:00 Go to previous messageGo to next message
cwhelan: look up the CAMS manual, it has all the specs required there, including sample designs etc...
cwhelan
Adelaide, Semaphore
Re: bolt together roll cage? Thu, 14 October 2004 03:07 Go to previous messageGo to next message
Thanks for that, will check it out tonight as I have limited access to the net here at work. I feel lucky enough to be able to access toymods forums, which i spend all day reading.... A good way to pass the day... Very Happy Cool
bbaacchhyy
Re: bolt together roll cage? Thu, 14 October 2004 03:11 Go to previous messageGo to next message
You have to buy the CAMS manual, and I doubt there are any new bolt together cages anymore, as they are now not legal in competition cars.
Michael B
PS I would not have an alloy or bolt together cage in any car that I own. I have seen the difference between them and a good weld-in cage, and the strength difference is chalk and cheese.
chubbylover53
Re: bolt together roll cage? Thu, 14 October 2004 09:37 Go to previous messageGo to next message
Righto. thanks for the advice. I need to think up of a new idea for my year 12 design tech project.
Sad
STR8 2.8
Re: bolt together roll cage? Thu, 14 October 2004 09:47 Go to previous messageGo to next message
chubbylover53 wrote on Thu, 14 October 2004 19:37
Sad
haha oh that year was fun!
build a new front bar, like i did! Very Happy
schnitzel
Bendigo
Re: bolt together roll cage? Thu, 14 October 2004 09:57 Go to previous messageGo to next message
I have been in 2 majors in rallies with bolt together roll bars by CDP Industries, one rolled twice the other barrel rolled 6 times, cages held together fine, pity the cars didn't survive but we basically walked away both times apart from harness bruising and very severely dented wallets.
regards
bbaacchhyy
Re: bolt together roll cage? Thu, 14 October 2004 21:43 Go to previous messageGo to next message
schnitzel wrote on Thu, 14 October 2004 19:57
regards
Remind me not to drive with you Rolling Eyes Good to hear that all is well though.
My dislike for bolt together cages is that the joints are not solid, and often the method of bolting into the car is not real flash.
Like the old helmet ad goae "If you have a $10 head, then buy a $10 helmet". My life is worth more, and in my RX2 Club car that i had, I spent about $1k getting a VERY good cage welded in that made me feel vey safe.
Michael B
schnitzel
Bendigo
Re: bolt together roll cage? Sun, 17 October 2004 23:19 Go to previous messageGo to next message
bbaacchhyy wrote on Fri, 15 October 2004 07:43
regards
Michael B
Actually I was only driving in one instance the really big omne I was the navigator, but it still all comes back to how they were made, these were all custom fitted and engineered to fit the particular car they wee fitted to, not bought off the shelf and fitted. Hence mounting points and braces were solid and correctly positioned to supplement the original strength in the shell. Agree that the only option is to buy the best that is available, hence I was using above the recommended spec Chrome Moly tube when everyone else wanted to use aluminium to save weight, the way I looked at it my head was woth more than saving 5 kilo's in weight, and as I said we both walked away without real damage.
p.s. seats and harness also need to be up to it, safety is a total package where all bits must be right and is more important than go fast bits at the end of the day.
regards
bbaacchhyy
Re: bolt together roll cage? Mon, 18 October 2004 00:15 Go to previous message
schnitzel wrote on Mon, 18 October 2004 09:19
regards
Couldn't agree more.
Previous Topic:7afe --->>> 7age conversion
Next Topic:3sge into ke25
Current Time: Sat Nov 21 04:56:36 UTC 2026
Total time taken to generate the page: 0.0068011283874512 seconds
