Toymods » Tech & Conversions » Max RPM on CT12's
BLK1GGTE
South Eastern Subs
Max RPM on CT12's Thu, 14 October 2004 04:39 Go to next message
I found this web site:
http://www.toysport.com/webpages/Techinfo/Referenc es/turbochargers.htm
and it says that maximum RPM allowable for CT12's is 1700000. So would anyone know to work out at what boost presure would the spin to this RPM.
Re: Max RPM on CT12's Thu, 14 October 2004 06:05 Go to previous messageGo to next message
There is no direct correlation between shaft RPM and boost pressure; there are too many other factors to consider.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: Max RPM on CT12's Thu, 14 October 2004 07:03 Go to previous messageGo to next message
One too many zeros!
You nearly gave me a heart attack!
BLK1GGTE
South Eastern Subs
Re: Max RPM on CT12's Thu, 14 October 2004 07:29 Go to previous messageGo to next message
Laughing so what is all taht info on that web page mean...
can ct 20 be bolted where ct12's are..i have no idea about this as i never seen a ct20 so this could be classified as a stupid question if you like Embarassed
Re: Max RPM on CT12's Thu, 14 October 2004 07:53 Go to previous messageGo to next message
means after that rpm, things won't hold together long Wink
as far as bolting up, it's a matter of bolt spacings etc...
there is far more to selecting a turbo than just bolting it on...
then again, just bolting it on is the easiest way to 'upgrade'
BLK1GGTE
South Eastern Subs
Re: Max RPM on CT12's Thu, 14 October 2004 08:11 Go to previous messageGo to next message
So which turbos would bolt on with out too many mods to the standard manifold and use the stadard piping..Anything..i am just curious cause i don't want to swap to a single if i ever blow these ct12's..I seen TD04 kits for 1ggte...any sugestions
Re: Max RPM on CT12's Thu, 14 October 2004 10:06 Go to previous messageGo to next message
the CT12's have a unique bolt/flange pattern - even the CT12A is different.
if you want an alternative turbo, you'll have to mod your existing manifold (why bother?) or fab a new one to suit your desired turbo.
to retain your current manifold setup requires using the CT12's exhaust housing - and if you don't want mod the intake piping then it's pretty much CT12s all the way.
popular position seems to be that you treat them as disposable - either replace when fubared or get new manifold and turbo.
[Updated on: Thu, 14 October 2004 11:31]
Re: Max RPM on CT12's Thu, 14 October 2004 10:31 Go to previous message
replace snafu with fubared
things dont "get" snafu'd... they're always like that (pet hate - misuse of those 2 words)
Previous Topic:If you had a stock Celica ST162
Next Topic:E282 DIFF ?
Current Time: Sun Oct 25 04:35:42 UTC 2026
Total time taken to generate the page: 0.0052978992462158 seconds
