Toymods » Tech & Conversions » To TVIS or not to TVIS....
DannyGT4
Toymods Board Member
To TVIS or not to TVIS.... Mon, 30 September 2002 09:50 Go to next message
that is the question...
ok i don't think its been discussed for a while so i'm interested in getting opinions
i'm rebuilding my 3sgte and i'm looking at the dodgy looking TVIS and wondering if its gonna be worth ditching...
as i can figure on a stock engine it serves a decent enough purpose but as i get more ambitious in my mods it becomes more restrictive than useful...
any opinions? anybody removed the TVIS with ill effects?
humble
Brisbane, QLD
Re: To TVIS or not to TVIS.... Mon, 30 September 2002 10:40 Go to previous messageGo to next message
Having had no personal experience with a TVIS equipped engine, all I can only offer is some theoretical insight...
TVIS (or Toyota Variable Induction System) was to my knowledge used in earlier 3S and 4A series Toyota motors. The goal of TVIS is to improve an engine's low rpm band torque. This is how it tries to achieves that goal.
When it comes to camshaft profile design on engines, non-variable
valve timing engines are always a compromise as the desginer has to make a design that is an appropriate trade-off between high-end power and low-end torque. By weighing a little more towards high-end power and little less towards low-end torque, you'd get valve timing that is more favourable to high-end power, but would result in rough idling and poor low-end torque. This is mostly due to the valve overlap resulting in a lower volumetric efficiency as at lower rpms due to the lower intake air interia as the engine's breathing rate is lower. What TVIS does is effectively halving the diameter of the intake runners, thus making the airflow twice as fast. This would allow for twice the inertia for the intake air and thus, the engine would experience higher volumetric efficiency. This process is called inertial supercharging.
One point that needs noting is that this is not actually counter productive because at lower rpms, the engine can breathe efficiently through intake runners with less cross section area.
The cross sectional area reduction is achieved by dividing each intake runner into two and placing butterfly valves that would only open after a certain rpm. At higher rpms (4200 on 3S-GTE?) the buterfly valves remain open and the system operates as if no TVIS was present. When butterfly valves are close, the TVIS effects come into play.
However, the TVIS system is more complex and more prone to failure (butterfly valves). This could be one of the reasons why Toyota abandoned this later on. There's obviously more than one way to skin a cat Smile The low-end torque versus high-end power compromise can be dealt with in a multitude of fashions and Toyota probably chose a simpler solution.
As for the performance mods, TVIS may or may not help you depending on your situtation. If your turbos spool up rather early, the TVIS would just be a restriction (maybe you can get the valves to open at a lower rpm). But however, if you Turbo's spool up later, then keeping TVIS might actually help. Having said that, the TVIS system (butterfly valves) does indeed add restrictions to the airflow and in your application, I am not sure if this would be significant. I'd say, if you have the ability to do so, have a play with it and see how it works for you. I hope this information helped you to get started Smile Of course, some might argue this is too much trouble and get rid of TVIS and be done with it... They do have a point too...
Hope this helps...
Nishad
Karl_skewes
New Zealand
Re: To TVIS or not to TVIS.... Wed, 02 October 2002 09:38 Go to previous messageGo to next message
run the tvis, the electronic one anyways.
On 10psi boost, and also on 140-150hp NA motor, it made for a smoother power curve, but you don't get the drag racer kick at 4000rpm.... if that matters to you.
jase
Re: To TVIS or not to TVIS.... Wed, 02 October 2002 09:57 Go to previous message
The experts can't agree on this one.
Toysport ion USA says keep it.
Phoenix's Power in Japan say ditch it. They even make a kit to do it. (but they also front mount mr2 intercoolers)
I think it depends on your target output. If your aiming really high (phoenix's power have a couple of cust's cars over 500ps - sheez - and sell TVIS deletion kits) then you need to get rid of it, but you also need a set of 272 cams, an aftermarket computer, and a crank to support 9000+ rpm. And your fuel system and intercooler need a change. Then theres the big hairdrier.
After a long think about it when rebuilding my engine (3sgte in MR2), I kept it.
In a GT4 I'd be even more inclined to keep it, unless, as mentioned above, you were going to go crazy.
But I'd make damn certain it was working perfectly.
Previous Topic: 85/86 hilux wiring diagram
Next Topic:Oil Temp Gauge for 4age
Current Time: Tue Oct 27 08:06:29 UTC 2026
Total time taken to generate the page: 0.0047509670257568 seconds
