Toymods » Tech & Conversions » early celica diff upgrades
brett_celicacoupe
townsville NQLD
early celica diff upgrades Thu, 14 October 2004 09:51 Go to next message
hi,
i know a guy who has a old pintara (auto-is that problem-ratios??) and he is willing to give the diff to me for no more than $50. ive read the tech sections and done searchs and i wanna kno more about if the pintara will go into a early celica(ra40). i dont kno wuch about diff's as i havent eva pulled one apart, and cant really put names to parts. so it is a little confusing but i will definitly understand when i pull one apart.
this is what i want
-a diff that will go in easily enough
-a diff that will take a decent amout of power. probly a 1g later on
-disk brakes
-be able to get a LSD centre later on down the track (cheaply)
do i use the whole pintara/skyline diff?? or just parts?
should i source a corona diff??
what about a LSD ae86 diff? what about hilux centre, does it go straight in?
also i have acces to a mx62(free) for a diff (does any1 kno about this)
and i can get a ta22 diff (free) also if this is any help
opinions please.....thanx
[Updated on: Thu, 14 October 2004 11:09]
rb20det
Re: early celica diff upgrades Thu, 14 October 2004 13:11 Go to previous messageGo to next message
if the pintara diff is the same as a r31 skyline then it would be a borgwarner 2 bolt diff non lsd they are a ok diff and can always be swapped for a 4 bolt lsd out of a vl/vn commonwhore. the conversion will cost you a bit if it needs shortened but if it doesnt it will be cheaper. also getting the brakes hooked up right might cost a bit
Lambolica
Northwestern Sydney
Re: early celica diff upgrades Thu, 14 October 2004 23:36 Go to previous messageGo to next message
To put it shortly, any other diff that can go into an early celica will need to have the mounts re welded to suit, or need to be shortened.
My pick would be get the diff from an MX23 and cut off the mounts and reweld on new ones, you *can* get away without needing to shorten the diff (thou rear offset needs to be looked at) and get corona rear disks put of. this gives you a disk rear end that fits up to the celica handbrake easily, and an F series diff that LSD gear sets are easily avaiable for.
Intensevil
Re: early celica diff upgrades Fri, 15 October 2004 02:45 Go to previous messageGo to next message
Lambolica wrote on Fri, 15 October 2004 09:36
Just where would you need to go to get a 1.5 way mech center for an f series diff?
wilbo666
Re: early celica diff upgrades Fri, 15 October 2004 03:43 Go to previous messageGo to next message
brett_celicacoupe wrote on Thu, 14 October 2004 19:51
Avoid it like the plague Wink
They are an E series which isn't used in much (hell if anyone knows where you can get an LSD for em I'd like to know...I know mx32's, mx62 and 80's taragos use E series and I also thought hiace? but I have no idea if any come with an LSD center).
If you want to go LSD one day down the track (only really know toyota so I'll stick to that and let the other boys ans the other bits) I'd also suggest a MX23 or MS112 (not sure the ms112 is the same width as the mx23 but it does have rear disk over the mx23 which does not). These diff's are F series and as such you can get an LSD from ma61 supras (and the front diff of some hilux's?)
brett_celicacoupe
townsville NQLD
Re: early celica diff upgrades Fri, 15 October 2004 10:21 Go to previous message
oh well thanx anyway
just wanted to put it though people seeing as the opportunity for a 50$ pintara diff came up. ill leave it go
Previous Topic:Vote #1: Stupidest turbo design
Next Topic:ae86 uni joints
Current Time: Fri Oct 16 12:04:30 UTC 2026
Total time taken to generate the page: 0.0045070648193359 seconds
