Toymods » The Outhouse » Windows XP & P2P?
Conquest
Sydney/Wollongong
Windows XP & P2P? Thu, 14 October 2004 11:12 Go to next message
Downloaded Emule (only a few years too late) but to work properly (i.e more sources, quicker downloads) apparently I need to disable my firewall.
I tried this with obvious results (RPC messages killed my computer!) so I need another way. Any suggestions? Can I enable specific ports without endangering my security?
RA28
Re: Windows XP & P2P? Thu, 14 October 2004 11:32 Go to previous messageGo to next message
Instead of turning off the firewall, find out the port emule uses and tell your firewall to forward that port.
Or just get a decent firewall and start from there.
Tim.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: Windows XP & P2P? Thu, 14 October 2004 11:50 Go to previous messageGo to next message
You won't need to forward the port, just open it up so that it will allow traffic through on that port.
MR 1JZ
Re: Windows XP & P2P? Fri, 15 October 2004 03:11 Go to previous messageGo to next message
or dont use crappy P2P programs like emule that a chocked up the wazoo with spyware Rolling Eyes
WINMX ALL TEH WAY!
but yeah tell emule to use port 6881 for incoming transmissions and 6999 for outgoing, worked a treat on my wireless router for ABC and WINMX
beterthenu
Dubbo NSW
Re: Windows XP & P2P? Fri, 15 October 2004 03:27 Go to previous messageGo to next message
emule, spyware? since when, its a sourceforge project, but anyway. port 6881 is primarly used for BT not emule. emule will use TCP port 4662 and UDP port 4672. and you dont NEED to have these ports open, only makes services like KAD network work better. to open the ports on windows firewall, go to your connection, right click, properties, advanced, then settings. click add type a description, put your computername in for name or ip address and enter you port numbers in the port number.
and yes any other firewall than M$ firewall would be better,might want to try kerio personal firewall, its free and works good.
EDIT
Theres even a button in emule to open the ports for you. its under preferences, connections.
[Updated on: Fri, 15 October 2004 03:37]
Conquest
Sydney/Wollongong
Re: Windows XP & P2P? Sat, 16 October 2004 13:59 Go to previous message
Thanks for they replies. Didn't see any button Confused But I forwarded the required ports through connection properties & as a result available files jumped from 200k to 20mil+
Despite that I still can't get what i'm after Mad Any way to jump the queue?
EDIT: Found the button, now that would've been simpler Razz Ah well, least now I know...
[Updated on: Mon, 18 October 2004 10:01]
Previous Topic:Do you have stairs in your house?
Next Topic:Buy Brooke's Beast!
Current Time: Thu Oct 29 07:35:34 UTC 2026
Total time taken to generate the page: 0.022005081176758 seconds
