Toymods » Tech & Conversions » Swapping 1JZ sumps
wilbo666
Swapping 1JZ sumps Fri, 15 October 2004 04:27 Go to next message
Hey guys, I currently have a Mid rear (jzz30) sump atm, and am arranging to do a swap to a front sump. What I'd like to know is, are the turbo drain pipes (the rubber ones) the same between all the sump models?
Am I correct in saying that all I need for the swap is
-sump (bottom metal piece of sump, windage tray and upper alloy section of sump)
-oil pickup
-dip stick
Chris Davey
sunny coast, qld
Re: Swapping 1JZ sumps Fri, 15 October 2004 04:29 Go to previous messageGo to next message
if i remember correctly the oil return lines are different. Usually the other ones would come with the sump though.
wilbo666
Re: Swapping 1JZ sumps Fri, 15 October 2004 04:42 Go to previous messageGo to next message
Sigh, well that'd be right! I might be missing one of the oil lines I think (will have to do a double check on that tho, only had a quick look to date!) Don't suppose you have a pic of a mid rear sump with turbo oil drain lines connected?
wilbo666
Re: Swapping 1JZ sumps Fri, 15 October 2004 04:49 Go to previous messageGo to next message
http://memimage.cardomain.net/member_images/11/web/215000-215999/215052_33_full.jpg
Compare to that (front sump obviously)!
Chris Davey
sunny coast, qld
Re: Swapping 1JZ sumps Fri, 15 October 2004 05:03 Go to previous messageGo to next message
hehe Smile Remember I have a mid sump engine in my garage as well as the front sump engine in my car Smile
I will get a pic tomorrow for you.
wilbo666
Re: Swapping 1JZ sumps Fri, 15 October 2004 05:07 Go to previous messageGo to next message
Chris Davey wrote on Fri, 15 October 2004 15:03
Aww tomorrow Razz hehe I guess that will do Wink
Ta
Chris Davey
sunny coast, qld
Re: Swapping 1JZ sumps Fri, 15 October 2004 08:33 Go to previous messageGo to next message
BTW I didn't see it on your list but there is a plate inside the sump that surrounds the oil pickup and I think it is to stop the oil surging of something like that. They are different between sumps but it all bolts up.
wilbo666
Re: Swapping 1JZ sumps Fri, 15 October 2004 10:21 Go to previous messageGo to next message
Yeah windage tray, I just call it part of the sump lol
Chris Davey
sunny coast, qld
Re: Swapping 1JZ sumps Fri, 15 October 2004 23:58 Go to previous messageGo to next message
Yep, they are different Smile
You need a front sump right? So you have a mid sump with no oil lines and you need the oil lines for the front sump like the one in your pic. I can give you one, but I cut the other one as I was pissed off at it and couldn't get the turbo off.
I don't think I will need them when I get the single turbo.
rest of pics at http://www.picturetrail.com/gallery/view?p=999& ;gid=5451076&uid=2681245&members=1
BTW take notice of the different mounting positions for the engine mounts. That one got me Smile
http://pic15.picturetrail.com/VOL620/2681245/5451076/69769465.jpg
[Updated on: Fri, 15 October 2004 23:59]
wilbo666
Re: Swapping 1JZ sumps Sat, 16 October 2004 00:47 Go to previous message
Wicked! Thats sorts me out Smile I'll just make sure I have lines to swap (looks like the metal ones are different as well Smile)!
Ta
Previous Topic:ST185 Suspension same as ST184?
Next Topic:Disabling speed chime?
Current Time: Sat Oct 24 02:26:53 UTC 2026
Total time taken to generate the page: 0.0061080455780029 seconds
