Toymods » Tech & Conversions » RHD JZA70
1jzsick
USA
RHD JZA70 Sat, 16 October 2004 18:01 Go to next message
I swapped a 1JZ into my 89 MA70
I was wondering if there was ever any RHD JZA70s because I trying to find the gauge cluster from JZA70 for the higher redline on the tach. Its just for looks but I can only find LHD gauge clusters
any tips where i can find a RHD gauge cluster or if they even exsist?
Chris Davey
sunny coast, qld
Re: RHD JZA70 Sat, 16 October 2004 21:57 Go to previous messageGo to next message
yes they do exist becuase that's how they are in Japan.
America is one of the only country's that would get them in LHD.
easiest place to find one if you have them there, is a half cut (clip Smile) importer. And see if you can buy just the dash.
If worst comes to worst, you could try australian importers but the jza70 half cuts are getting a bit rare from what I have seen.
1jzsick
USA
Re: RHD JZA70 Sun, 17 October 2004 00:18 Go to previous messageGo to next message
whoops
i meant to say i have a LHD JZA70, I am in the US
So i need a LHD gauge cluster
I was groggy this morning heh
Does Australia use RHD or LHD
the cluster that came with the half cut i bought from japan is of course RHD
Re: RHD JZA70 Sun, 17 October 2004 03:07 Go to previous messageGo to next message
We're RHD over here. If you want a LHD JZA70 dash, you're out of luck; the JZA70 was only sold in Japan, ie RHD.
wagonist
Toymods Club Treasurer
Re: RHD JZA70 Sun, 17 October 2004 23:37 Go to previous messageGo to next message
You might be able to disassemble the cluster & swap over the tacho face & motor.
Is the speedo driven electronically or by cable.
You may find that Toyota have put the same cluster in both cars regardless of where it went to (except for your "miles" Razz )
1jzsick
USA
Re: RHD JZA70 Mon, 18 October 2004 00:15 Go to previous messageGo to next message
the speedo is cable driven
i think i might do that
I also emailed www.speedhut.com and asked them if they can change the redline on the whiteface gauges they sell
wagonist
Re: RHD JZA70 Mon, 18 October 2004 00:37 Go to previous messageGo to next message
If the speedo is cable driven, there may be an issue as the speedo & tacho will have been swapped over from the RHD to LHD.
If they are identical size though, they still might be able to be swapped.
Just swapping the guage face was be the easiest though.
lumpy
Adelaide, SA
Re: RHD JZA70 Mon, 18 October 2004 02:56 Go to previous message
It was easy for me to swap from ma70 analouge Tach face to jza70 face (with the 8k redline) - We even kept the same ma70 needle so it matched everything else! You can change the backing plate over and swap the "daughter" board from the electonics of the jza70 tach to the ma70 one. You only have to swap the small board, not the whole mechanism. It's a pain to pull out, but looks pretty good when done.
I went from RHD to RHD though - still, I'm not sure why the LHD drive setup would be any different??
Caelum
Previous Topic:which diff?
Next Topic:RA23 retractable seatbelts
Current Time: Sat Oct 24 09:42:22 UTC 2026
Total time taken to generate the page: 0.0048410892486572 seconds
