Toymods » Tech & Conversions » setting cams
Simon-AE86
Banned user
ADELAIDE - The Drift City
setting cams Tue, 01 October 2002 02:03 Go to next message
I have a new ae86 which has a 190hp 4age in it. The cams currently are all out of wack and atm it makes borderline power, i need to set them.. How do i go about doing this without the cam specs and so on?
what would the correct procedure for this be?
at TDC what should my inlet and exahust valves be doing?
5KinKP60
Finland
Re: setting cams Tue, 01 October 2002 09:25 Go to previous message
Yes, you can do it either that way, or determine at what degree they should be fully open.
I myself have adobted "full lift at xxx degrees"-method. More clear this way me thinks.
I do have an advantage since my pushrodder engine has inlet and exhaust valves operated by single cam. I tweak inlet spot on, and exhaust will follow. Twin cams = double the labour.
If you just need to have it running, and you're sure you have radical cams installed, just dial in say... inlet fully open at 102º ATDC. Dial in lobe separation of about 103º to 106º.
That should get you started, and who knows could be pretty close to final settings.
-A.
Previous Topic:Weight balance of the Supra
Next Topic:the final word on getting an r154 (ijz manual) box into a ma61 supra
Current Time: Sat Oct 31 16:08:48 UTC 2026
Total time taken to generate the page: 0.15339016914368 seconds
