Toymods » Tech & Conversions » KE20 Modifcations
CryptOrchid
KE20 Modifcations Sun, 17 October 2004 08:29 Go to next message
Hi all, I'm just after some info on modifying my KE20. Basically I'd like it set up for good handling and am also thinking of an engine conversion sometime in the future. So with these goals in mind I was hoping I could be such advice as, a)What is a suitable wheel/tyre size b)What is a good suspension setup and c)What would be the best engine/gearbox to transplant into it?
YelloRolla
On your mum!
Re: KE20 Modifcations Sun, 17 October 2004 08:41 Go to previous messageGo to next message
Best engine/gearbox would be the 4A series.
Suspension could go well with coil overs up front (I have yet to see what good brake upgrades fit the std struts - spose you could use something from Wilwood)
I have a 24mm sway bar up front - it could use a panhard rod out back.
I reckon 15 x 7 would be ample big enough for the 20.
These are just some thoughts and it bears little semblance of what I have currently done to mine.
twincam_ke20
Castlemaine Vic
Re: KE20 Modifcations Sun, 17 October 2004 08:52 Go to previous messageGo to next message
yellorolla: what brand is your sway bar? whiteline only seem to make 16mm front +rear.
YelloRolla
On your mum!
Re: KE20 Modifcations Sun, 17 October 2004 10:09 Go to previous messageGo to next message
Kmac
CryptOrchid
Re: KE20 Modifcations Sun, 17 October 2004 10:39 Go to previous messageGo to next message
Isn't it more expensive to install say a 4A-GE because it's a front wheel drive engine and requires more mods? Where is a good place to go to get suspension done?
twincam_ke20
Castlemaine Vic
Re: KE20 Modifcations Sun, 17 October 2004 11:05 Go to previous message
YelloRolla: i just went to their site but couldnt find a listing on sway bars Confused may i ask roughly what you paid for it?
CryptOrchid: sorry to have hyjacked ya thread Embarassed
also, you can get rwd 4age's, just a little harder to find and a little more $$$ then the fwd ones. but theres nothing wrong with a fwd 4age, and not that hard to make it rwd either.
do a search on here cos im sure its been covered a heap, converting FWD to RWD.
Previous Topic:KE30 Steering Rack conversion???
Next Topic:On Site Auto Electrician Wanted
Current Time: Fri Nov 20 13:51:55 UTC 2026
Total time taken to generate the page: 0.0049619674682617 seconds
