Toymods » Tech & Conversions » springs for TEMS suspension
b1gb3n
south Melbourne/KL
springs for TEMS suspension Mon, 18 October 2004 04:49 Go to next message
i have an ae92 levin and i want to get some lowered springs. Would the springs for australian ae92s fit on my car?? would it affect my TEMS system??
b1gb3n
south Melbourne/KL
Re: springs for TEMS suspension Mon, 18 October 2004 11:51 Go to previous messageGo to next message
can i lower my car with tems suspension on??
anybody??
b1gb3n
south Melbourne/KL
Re: springs for TEMS suspension Fri, 22 October 2004 05:56 Go to previous messageGo to next message
anybody??
indian
south east - melbourne
Re: springs for TEMS suspension Fri, 22 October 2004 06:26 Go to previous messageGo to next message
yeah temsis just the damper rate thats what ivebeen told , im gnnabe doing the lowering of my soarer on normal tems suspension , u should be right to do it
Alainve
Newcastle NSW
Re: springs for TEMS suspension Fri, 22 October 2004 06:42 Go to previous messageGo to next message
AE92's had TEMS?
i have never seen this as an option..
u are aware TEMS is Toyota Electronically Modulated Suspension.
and it is an airbag system with no springs as far as i am aware.
with the soarers its just a case of reseting the sensor to make it think its at the correct height still.
b1gb3n
south Melbourne/KL
Re: springs for TEMS suspension Fri, 22 October 2004 06:49 Go to previous messageGo to next message
mines ae92 levin.
airbag with no springs??? damn im going down to check now!!
indian
Re: springs for TEMS suspension Fri, 22 October 2004 07:15 Go to previous messageGo to next message
tems doesnot have airbags its just normal springs but the shckabsorbers are electronically adjusted for damper control to make te ride harder or softer
u can remove the springs like normal car and pt in lowrered springs ,
thats what i will be doing soon
soarers also come in airbag suspension v8s and the mz21 series had them
ive got the soarer with tems suspension and i can confirm 100% they are springs
Shraka
Re: springs for TEMS suspension Fri, 22 October 2004 07:18 Go to previous messageGo to next message
TEMS isn't airbag suspension. Different. TEMS is the adjustable damper.
b1gb3n
south Melbourne/KL
i just checked and THEY DO HAVE SPRINGS!!!
Alainve
Newcastle NSW
Re: springs for TEMS suspension Fri, 22 October 2004 09:41 Go to previous messageGo to next message
ok my mistake there Embarassed but crowns with tems are height adjustable and i thought this was done by airbags? i think its time for me to do some more research...
Alainve
Newcastle NSW
Re: springs for TEMS suspension Fri, 22 October 2004 09:59 Go to previous messageGo to next message
http://www.supras.co.uk/resources/MkIII/tips/suspe nsion.htm
i did some reaserch its for a Mk3 supras tems but the process is the same with the AE92.
hope this helps
b1gb3n
south Melbourne/KL
Re: springs for TEMS suspension Fri, 22 October 2004 11:39 Go to previous messageGo to next message
Alainve wrote on Fri, 22 October 2004 19:59
hope this helps
thanks man!!
damn it sounds complicated!! better print it out!!
BLK1GGTE
South Eastern Subs
Re: springs for TEMS suspension Sat, 23 October 2004 03:46 Go to previous messageGo to next message
You can lower terms like any coil over suspension.. Just be carefull how much cause they don't have much travell to start with..Anything over two inces and you are ridding on bump stops...which can be bad for your kindeys...
b1gb3n
south Melbourne/KL
Re: springs for TEMS suspension Sat, 23 October 2004 08:10 Go to previous messageGo to next message
BLK1GGTE wrote on Sat, 23 October 2004 13:46
this applies to ae92 as well?? u sure??
Alainve
Newcastle NSW
Re: springs for TEMS suspension Sat, 23 October 2004 08:55 Go to previous messageGo to next message
that applies to almost any car dont go too far
BLK1GGTE
South Eastern Subs
Re: springs for TEMS suspension Sun, 24 October 2004 05:20 Go to previous message
Yep would be same for all cars...like Alainve said..No more then two incehs and it should be ok..But the ride will be err more anoying when you are just cruzing..depends what spirngs u get..
Previous Topic:Which LSD for TA22
Next Topic:1jz single turbo selection
Current Time: Thu Nov 19 10:15:36 UTC 2026
Total time taken to generate the page: 0.0076930522918701 seconds
