Classifieds » Miscellaneous » Syd - Stainless tube, 12 & 16mm
clubagreenie
1st street on the right
Syd - Stainless tube, 12 & 16mm Mon, 18 October 2004 10:31 Go to next message
Have 12 meters of 16mm od and 192 meters of 12mm od. All seamless Sandvik hyd tube, rated for pressure beyond anything you bozo's will do to it. Ideal for fuel, auto cooling tubes or maybe turbo drain? 12mm is 1.5 wall thickness and 16mm is 2.0 wall
All in 6 meter lengths. Pickup in Syd only (I'm not driving ATM & so cant deliver) or can ship if you arrange.
12mm $25- length or $6- meter
16mm $35- length or $9- meter
Or $500- ONO for the lot
Believe me wholesale is a lot more than this but retail is even worse.
Pls PM if you want any so I can keep a record of "orders"
J
[Updated on: Mon, 18 October 2004 19:41]
fade-e
Re: Syd - Stainless tube, 12 & 16mm Mon, 18 October 2004 10:57 Go to previous messageGo to next message
are the thicknesses inner diameter or outer?
if outer then what is the inner diameter?
Re: Syd - Stainless tube, 12 & 16mm Thu, 21 October 2004 06:31 Go to previous messageGo to next message
clubagreenie wrote on Mon, 18 October 2004 20:31
Have 12 meters of 16mm OD and 192 meters of 12mm OD. 12mm is 1.5 wall thickness and 16mm is 2.0 wall
damn thats cheap.. i wonder if i can think of anything to do with it.... Wink
clubagreenie
Re: Syd - Stainless tube, 12 & 16mm Thu, 21 October 2004 09:54 Go to previous message
DIY oil cooler, small tube and fin intercooler, fuel, oil, water (small) lines, high capacity windscreen washer tube (no more resovoir) high volume barke lines, buy the lot for a S/S multi tube roll cage. The possibilties are endless.
Previous Topic:AE82 twincam handbrake cables
Next Topic:SWAP muffler!!
Current Time: Thu Oct 29 08:01:47 UTC 2026
Total time taken to generate the page: 0.010094881057739 seconds
