Toymods » Tech & Conversions » Why are my Thermo Fans on??
chrizer
Why are my Thermo Fans on?? Mon, 18 October 2004 10:44 Go to next message
I just finished my airbox for my car. Then changed my oil, went to start the car, turned it on reds and my thermo fans cranked up. The temp gauge is reaqding dead cold. Whats going on, they are suppose to come on at 90 degrees.
Have I earthed something or what???
colouring_in_book
Re: Why are my Thermo Fans on?? Mon, 18 October 2004 11:02 Go to previous messageGo to next message
It is a very high possibilty that you have earthed something out yes.
This is a safety precaution set by the manfaturer, to help prevent overheating in an open circuit, ground or extremely high resistance situation of the sensor to ecu circuit.
Is it possible that you have accidently unplugged something, ripped out some wiring etc when you were fiddling around with your car?
wagonist
Toymods Club Treasurer
Re: Why are my Thermo Fans on?? Tue, 19 October 2004 02:31 Go to previous messageGo to next message
Is your air con on? This turns on the fans no matter cold the engine is.
Celica_John
Re: Why are my Thermo Fans on?? Tue, 19 October 2004 02:33 Go to previous messageGo to next message
replace the temp switch. on my st162 its under the alternator i think.
dingaling
tas
Re: Why are my Thermo Fans on?? Tue, 19 October 2004 03:28 Go to previous messageGo to next message
If the plug on the thermo switch is off and not making contact the fans will stay on until it's plugged back into the thermo switch near the alternator like celica_john said.
indian
south east - melbourne
Re: Why are my Thermo Fans on?? Tue, 19 October 2004 03:35 Go to previous messageGo to next message
wtf my soarer has the big fan behind the radiator always on even on idle when the car has been started , how s it supposed to be then
damn
Celica_John
Re: Why are my Thermo Fans on?? Tue, 19 October 2004 03:36 Go to previous messageGo to next message
yep but if the connection is good the sensor could be faulty.
wagonist
Re: Why are my Thermo Fans on?? Tue, 19 October 2004 03:47 Go to previous messageGo to next message
Sounds like a fail safe system in case the sensor screws up, less chance of cooking the engine.
Celica_John
Re: Why are my Thermo Fans on?? Tue, 19 October 2004 03:55 Go to previous messageGo to next message
I've got a sensor from a wrecker before that kept the thermo fans switched off so maybe its the luck of the draw.
dingaling
tas
Re: Why are my Thermo Fans on?? Tue, 19 October 2004 11:33 Go to previous message
Yeah it's safe design for if the wiring goes bad, fans on all the time. But if the thermo sensor fails, fans never come on like my mums camry, poor engine was cooking it seld for months with no cooling.
It seems the thermo sensor makes a conductive connection to the earth/negative once the coolant reaches a certain temprature, and the fans come on and turn themselvs off again when they get the coolant temprature down.
I took my mums thermo sensor out, cleaned it and put it back in, aswell as getting all the air out of the cooling system.
It's working properly again.
Previous Topic:4age curiousity
Next Topic:3S-GE to 3S-GTE
Current Time: Sat Oct 17 19:05:07 UTC 2026
Total time taken to generate the page: 0.005012035369873 seconds
