Toymods » Tech & Conversions » 5m-ge HELP
Aydrianp
5m-ge HELP Mon, 18 October 2004 12:41 Go to next message
Is there anyone at all in the brisbane area that could please help me with a few 5M-GE problems
STR8 2.8
Re: 5m-ge HELP Mon, 18 October 2004 12:56 Go to previous messageGo to next message
whats wrong with it?
Aydrianp
Re: 5m-ge HELP Tue, 19 October 2004 01:54 Go to previous messageGo to next message
I done the 5m-ge conversion, but the fella that did the electrics cut the o2 sensor off the loom so i have driving around without the o2 sensor connected and the idle speed control valve is not connected properly either. So i have been driving the car around like that for a good 6 months now, and now my car is off the road again due to no spark. I have replaced the ignition coil and had the distributor checked and still no spark??????
Re: 5m-ge HELP Tue, 19 October 2004 02:53 Go to previous messageGo to next message
you need to refer to a TSRM for a Mk2, see here:
<http://www.cygnusx1.net/supra/techtips.html>.
i'd suggest that you check that the wiring between the ECU and various doubtful components (like the dizzi, ignitor, o2 sensor, ISCV, etc) is intact by doing continuity checks and then refer to the diagnostic pages in the same manual to see how you can get various things working or diagnosed as stuffed.
even tho its for a newer car, it's <http://www.cygnusx1.net/supra/library/TSRM_MKII/in dex.html> is for a 5MGE engine in a supra.
Also - no spark could also be the ignitor not getting a signal from the ECU, or the pickup in the dizzi no sending to the ECU or the ignitor being stuffed.
you'll use a lot less fuel if there is an O2 sensor - tho only at idle or cruise.
Supralux
Re: 5m-ge HELP Tue, 19 October 2004 05:56 Go to previous messageGo to next message
so you have tested for spark at the end of the leads?
my 5mge would not fire at all because plugs were fouled.
Aydrianp
Re: 5m-ge HELP Tue, 19 October 2004 07:54 Go to previous messageGo to next message
it doesn't spark at the end of the lead that comes from the ignition coil
Re: 5m-ge HELP Tue, 19 October 2004 09:57 Go to previous message
you need to work out if the ignitor is triggering the coil - or check that there is 12V a the + terminal at the coil... for starters.
checked all your connectors and fuses?
Previous Topic:MA61 headlight / bonnet clearance problem???
Next Topic:Suggestions/options please
Current Time: Wed Oct 14 04:38:17 UTC 2026
Total time taken to generate the page: 0.068727970123291 seconds
