Toymods » Tech & Conversions » Need Help With GT4 :(
TitMeat
Need Help With GT4 :( Mon, 18 October 2004 15:32 Go to next message
I was driving my st185 gt4 today at about 140 in 5th gear and it suddenly lost boost Sad it was like i was driving a NA car ....hope i havent f****d the turbo Neutral ...does anyone have any idea what it could be ?
Draza
Wahroonga
Re: Need Help With GT4 :( Tue, 19 October 2004 01:57 Go to previous messageGo to next message
were you on high boost, cos it might be the boost limiter. Drive it again, and see if it will go on boost, if it drives fine you probally just hit the boost limiter. If it still won't go on boost, check that all the hoses/pipes from turbo to intercooler to induction are ok.
TitMeat
Re: Need Help With GT4 :( Tue, 19 October 2004 06:37 Go to previous messageGo to next message
i drove it but it still wont go on boost .. i checked the pipes but i couldnt see anything wrong ...but i could be mistaken ...i did notice yesterday after i finished driving it i could hear a strange hissing noise coming from the intercooler...
tooch
Bulleen, Melbourne
Re: Need Help With GT4 :( Tue, 19 October 2004 08:01 Go to previous messageGo to next message
Is your check engine light on? Pull the codes from the ECU anyway and see if it comes up with anything. Sounds like what mine did when the knock sensor went, throws the car into a safe mode.
TitMeat
Re: Need Help With GT4 :( Tue, 19 October 2004 08:18 Go to previous messageGo to next message
nah no check engine light comes on Neutral
SilverGhost
Re: Need Help With GT4 :( Tue, 19 October 2004 08:35 Go to previous messageGo to next message
a hissing noise from the intercooler could mean a leak like a weld or one of the fins cracked under boost....see if you can locate the source of the noise on the IC.
if you suspect a leak but cant track it down over engine noise you can even take it off the car, just seal one end with your hand and blow into it to see if it leaks.
If your IC has a leak then thats your loss of boost...
Just pray that nothing foreign has entered your turbo and has damaged your turbine or compressor, worst case scenario is something was sucked into your intake, damaged your compressor and a part of the compressor itself is lodged in your IC either causing a leak of its own or a hissing noise by obstructing one of the fins.
73ke25
adelaide
Re: Need Help With GT4 :( Tue, 19 October 2004 08:42 Go to previous message
Have you got a bov ? check all the small vac lines for cracks and make sure there are no loose ones.
Previous Topic:4AGTE Questions
Next Topic:anyone know anything about the stealshield ss900 car alarm????
Current Time: Tue Oct 20 23:53:17 UTC 2026
Total time taken to generate the page: 0.069902896881104 seconds
