Toymods » Tech & Conversions » 1G-GE Hunting at idle
Jarvis
1G-GE Hunting at idle Tue, 19 October 2004 02:27 Go to next message
Hey guys, got a 1G-GE in RA40 that hunts at idle once warm. does it with clutch in or out, in gear or nuetral. if you just touch the accelerator (pretty sensitive) and put a fraction of load on it stops and by load i'm talking less than 100-200rpm it goes away. The hunt is around 400rpm from it's highest to lowest and can get the engine pretty rough when it drop revs in the hunt. Any ideas before i take it to an injection mob???
Cheers Jarvis Confused
HyDrA
Adelaide, SA
Re: 1G-GE Hunting at idle Tue, 19 October 2004 02:29 Go to previous messageGo to next message
Have you got power to the ISCV?
I had similar troubles, in the end it was the ISCV not getting any juice.
Jarvis
Re: 1G-GE Hunting at idle Tue, 19 October 2004 02:32 Go to previous messageGo to next message
Sorry dude, what is the ISCV? I'm new to injection and Toyotas so bear with me.
monkeymajik
Re: 1G-GE Hunting at idle Tue, 19 October 2004 02:35 Go to previous messageGo to next message
Idle Speed Control Valve its on the throttle body/inlet on a 4a. Im guessing it would be in a simular spot on your 1g
[Updated on: Tue, 19 October 2004 02:46]
Jarvis
Re: 1G-GE Hunting at idle Tue, 19 October 2004 02:39 Go to previous messageGo to next message
CHEERS I'LL CHECK THAT. THANKS GUYS LET U KNOW....
dingaling
tas
Re: 1G-GE Hunting at idle Tue, 19 October 2004 03:31 Go to previous messageGo to next message
dunno if it's of any help, but i inscreased the idle speed on a friends celica abit and the hunting idle evened out to a steady idle. I could not locate any vacuum leaks etc.
HyDrA
Adelaide, SA
Re: 1G-GE Hunting at idle Tue, 19 October 2004 03:44 Go to previous messageGo to next message
Idle should be around 800rpm I think.
If the ISCV isnt getting power, and is letting air in, the idle can be screwed.
EvilJack
Sutho/Hills NSW
Re: 1G-GE Hunting at idle Tue, 19 October 2004 04:53 Go to previous messageGo to next message
check timing
Re: 1G-GE Hunting at idle Tue, 19 October 2004 05:13 Go to previous messageGo to next message
Also clean the ISCV with some carby cleaner, it gets gummed up and doesn't move properly
Jarvis
Re: 1G-GE Hunting at idle Tue, 26 October 2004 00:58 Go to previous messageGo to next message
DOES ANYONE KNOW WAHT THE FACTORY IDLE SPEED OF A 1G-GE IS???? Razz
Re: 1G-GE Hunting at idle Tue, 26 October 2004 01:06 Go to previous messageGo to next message
Auto or manual?
Most Toyota's are 750-800 in neutral, aircon off.
650 in gear, aircon off
800-850 in neutral, aircon on.
Thats something to work with.
Jorrs
Coffs Harbour
Re: 1G-GE Hunting at idle Tue, 26 October 2004 02:07 Go to previous messageGo to next message
hey dood i have exactly the same probelm with my st162 3sge celica i mean exactly wat u said applies to mine as well, im not sure wat the probel mis either on mine ive had it checked out and done lots things , i think it might be my o2 sensor or AF meter but not to sure as i didnt get any error codes from the ecu bout the 02 sensor , im takin my car to dyno place and everythin in bout 2 weeks to see if i can find outs wats goin on.
stradlater
Arthurs Creek, Victoria
Re: 1G-GE Hunting at idle Tue, 26 October 2004 06:55 Go to previous messageGo to next message
I tell you what, the english is this forum is exemplary. The above message is a great example of how well constructed some sentences are and just how clear the english is.
Jorrs
Coffs Harbour
Re: 1G-GE Hunting at idle Tue, 26 October 2004 07:16 Go to previous messageGo to next message
awwwwwwwwwwwwwwwww
cry me a river................
Jorrs
Coffs Harbour
Re: 1G-GE Hunting at idle Tue, 26 October 2004 07:26 Go to previous messageGo to next message
stradlater wrote on Tue, 26 October 2004 16:55
Also Hypocrite "the english is this forum" doesnt make sense to me ???
Re: 1G-GE Hunting at idle Tue, 26 October 2004 07:33 Go to previous messageGo to next message
Jorrs wrote on Tue, 26 October 2004 15:26
You seriously aren't comparing a simple typo to that crap you typed before are you?
Please tell me you're not.
knackers
berala sydney
Re: 1G-GE Hunting at idle Tue, 26 October 2004 10:45 Go to previous messageGo to next message
hi jarvis
I had the same problem with my 1g.In the end i got sideshow to check it out and the man is a genius.He is on the forum so give him a ring .He has a mobile service as well and his prices are great value
cya knackers
ChuckLandwehr
Re: 1G-GE Hunting at idle Tue, 26 October 2004 12:29 Go to previous messageGo to next message
1G-GTE same problem, hunting at idle. Changed Air Flow Meter, no more hunting. Cool
regards Chuck.
stradlater
Re: 1G-GE Hunting at idle Tue, 26 October 2004 23:33 Go to previous message
God damn it! I knew I'd screw up my criticism somewhere!! Shit, should have proof read it.. Well, kudos to you, you found the error.
Previous Topic:The 3SGE, apparent successor to the 3T... Bolts up?
Next Topic:what in the world is a Helica LSD (I am silly ignore me)
Current Time: Sun Oct 25 22:27:28 UTC 2026
Total time taken to generate the page: 0.048878908157349 seconds
