Toymods » Tech & Conversions » 1G-GTE air intake TEMP sensor??
HyDrA
Adelaide, SA
icon5.gif  1G-GTE air intake TEMP sensor?? Tue, 19 October 2004 05:36 Go to next message
Hi all,
While cruising up hills, at speeds around 90km/h and over, I find that the check engine light comes on, but the car still performs normally. The first time this happened I pulled over quick smart and checked the error codes. It spewed out one code, the code for air intake sensor.
Can someone tell me where this sensor is? Unless it's that little black stub built into the AFM, I can't see it. I'd have thought that it'd be between the intercooler and the intake side of the head somewhere, but i'm probably wrong Smile
I did a search, not much help...
EDIT: I am stupid and forgot to mention it was the air intake TEMP sensor. Someone slap some sense into my brain!
[Updated on: Tue, 19 October 2004 06:23]
matt_84
Ipswich
Re: 1G-GTE air intake sensor?? Tue, 19 October 2004 05:37 Go to previous messageGo to next message
I'm pretty sure its the little black stub. Good luck
EDIT: I assumed you meant intake temp sensor
[Updated on: Tue, 19 October 2004 05:39]
Re: 1G-GTE air intake sensor?? Tue, 19 October 2004 05:38 Go to previous messageGo to next message
air intake sensor?
or air intake TEMP sensor?
HyDrA
Adelaide, SA
Re: 1G-GTE air intake sensor?? Tue, 19 October 2004 05:46 Go to previous messageGo to next message
Air intake temp sensor Embarassed
24 Intake air thermo sensor signal Open or short circuit in intake air temperature sensor 1. Air intake temp. circuit
2. Air intake temp sensor
3. ECU
I'll recheck tonight to make sure I got it right.
Re: 1G-GTE air intake sensor?? Tue, 19 October 2004 05:51 Go to previous messageGo to next message
It has obviously failed, or the wire between it and the ecu has come unplugged. (providing that is the fault)
It wont affect anything major, unless you are driving though a volcano or a blizzard.
HyDrA
Adelaide, SA
Re: 1G-GTE air intake sensor?? Tue, 19 October 2004 06:22 Go to previous messageGo to next message
Fair enough, I'll remember to not drive through the next volcano I come across... I'll write it down on my dashboard, just to be sure.
Sorry, i've had a long day at work with kids making noise and such. My head hurts.
Cheers for the help!
RA28
Re: 1G-GTE air intake TEMP sensor?? Tue, 19 October 2004 12:52 Go to previous message
I thought the intake air temp sensor was built into the airflow meter.
Tim.
Previous Topic:water pump problems -IDENTIFICATION
Next Topic:21R-Z (RA60 + SC14)
Current Time: Wed Oct 21 10:54:45 UTC 2026
Total time taken to generate the page: 0.0051429271697998 seconds
