Toymods » Tech & Conversions » 4AGZE fuel rail and injectors into 4AGE bigport
4ageeza
Adelaide, drift capital
4AGZE fuel rail and injectors into 4AGE bigport Tue, 19 October 2004 08:08 Go to next message
Hi all,
I have seached for this topic high and low, on this site. Does anyone know whats required to fit my GZE fuel rail and injectors to my Bigport? Are there any real issues with this? I currently have a Microshit ECU. Would this mod at all be possible with a stock ECU?
Joel
feral4mr2
Bundaberg, Qld.
Re: 4AGZE fuel rail and injectors into 4AGE bigport Tue, 19 October 2004 08:58 Go to previous messageGo to next message
why do you need the 4agze fuel rail? you can just put the 4agze injectors on with the 4age fuel rail.
not 100% sure, but i think the injector plugs are different between the 2 engine looms.
[Updated on: Tue, 19 October 2004 08:59]
4ageeza
Re: 4AGZE fuel rail and injectors into 4AGE bigport Wed, 20 October 2004 03:19 Go to previous messageGo to next message
bumpy. Anyone done this conversion before? I'm sure someone has.
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: 4AGZE fuel rail and injectors into 4AGE bigport Sat, 23 October 2004 11:47 Go to previous messageGo to next message
bump for the smack talker!
takai
Re: 4AGZE fuel rail and injectors into 4AGE bigport Sat, 23 October 2004 23:07 Go to previous messageGo to next message
Yes, plugs are different, one is low ohm the other high ohm. The MT8 which i had had issues with switching between the two, so it may not be able to do it. The stock ecu wont do it, for the same reason.
EVOSTi
cambo
      no
Re: 4AGZE fuel rail and injectors into 4AGE bigport Sun, 24 October 2004 11:19 Go to previous messageGo to next message
physically bolts in tho.
TE72_Turbo
Re: 4AGZE fuel rail and injectors into 4AGE bigport Sun, 24 October 2004 12:02 Go to previous messageGo to next message
Is your GZE a small or bigport head variant?
If it is a smallport, then the fuel rail won't fit (injector spacing is different), you will need the rail from the bigport, which you can fit the GZE injectors into.
And yes, injector plugs are definately different.
Phil
takai
Re: 4AGZE fuel rail and injectors into 4AGE bigport Sun, 24 October 2004 12:13 Go to previous messageGo to next message
The injectors still fit in the 100kw manifold/railthough.
Re: 4AGZE fuel rail and injectors into 4AGE bigport Sun, 24 October 2004 12:16 Go to previous messageGo to next message
on a smallport, both the injectors and fuel rails are interchangeable between 4age and 4agze.
A bigport head has different spacing for the injectors, hence you will need to use a fuel rail from a bigport.
TE72_Turbo
Re: 4AGZE fuel rail and injectors into 4AGE bigport Sun, 24 October 2004 12:18 Go to previous messageGo to next message
Yes, all 16V 4AG/ZE injectors are physically interchangeable with the appropriate fuel rail. Smile
Re: 4AGZE fuel rail and injectors into 4AGE bigport Sun, 24 October 2004 12:57 Go to previous messageGo to next message
I presume your 4AG is making enough power to actually NEED the bigger injectors, and you're not just slipping them in because you can?
4ageeza
Re: 4AGZE fuel rail and injectors into 4AGE bigport Sun, 24 October 2004 14:32 Go to previous messageGo to next message
Cheers for your replies all. Both my 4AGE and 4AGZE are both bigports.
The reason I ask of this is that I only have the 4AGE running atm, and hope to make some more power with bigger injectors. The 4AGE is fairly stock, and running a Microtech Digi 2 Pro ECU.
Joel
Re: 4AGZE fuel rail and injectors into 4AGE bigport Mon, 25 October 2004 01:13 Go to previous messageGo to next message
4ageeza wrote on Mon, 25 October 2004 00:32
Joel
More power from bigger injectors alone - you are kidding right?
4ageeza
Re: 4AGZE fuel rail and injectors into 4AGE bigport Mon, 25 October 2004 02:15 Go to previous messageGo to next message
THE WITZL wrote on Mon, 25 October 2004 10:43
Joel
lolol, Its actually just a start because I currently have these injectors lying around. When I get more money I will be looking into other mods, dont worry! Smile
EVOSTi
cambo
      no
Re: 4AGZE fuel rail and injectors into 4AGE bigport Mon, 25 October 2004 11:12 Go to previous message
if you put bigger injectors in you will need your computer retuned, and you will gain a 0% power increase. why bother.
Previous Topic:Is it worth putting aftermarket EMS on a 1G..pls help
Next Topic:4ag Head Studs
Current Time: Fri Oct 23 10:27:26 UTC 2026
Total time taken to generate the page: 0.0061681270599365 seconds
