Toymods » Tech & Conversions » 4A-C Help Needed Urgently
Currently-Carless
4A-C Help Needed Urgently Tue, 19 October 2004 08:31 Go to next message
My sprinter engine has suddenly started running rough in the bottom half of the rev range. Worked fine this morning, but when I started it after work this afternoon, it started idling rough. Does anyone have any suggestions as to what it may be? I have already checked the spark leads and distributor. Don't think it will be the plugs, because they were replaced on the weekend. I'm hoping it isn't a blown head gasket, but so far, it is all I can think of. Any help would be greatly appreciated.
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: 4A-C Help Needed Urgently Tue, 19 October 2004 08:56 Go to previous messageGo to next message
vacuum leaks.
IRA11Y
Club Member
Re: 4A-C Help Needed Urgently Tue, 19 October 2004 08:57 Go to previous messageGo to next message
agreed you have a air leak problem, probhably on the manifold gasket or a vacume line has cracked or fallen off
Bobski
Re: 4A-C Help Needed Urgently Tue, 19 October 2004 10:23 Go to previous messageGo to next message
also check the choke butterfly in ur carb, if its buggered cable tie it open so the engine revs dont shake it about
Adam
Currently-Carless
Re: 4A-C Help Needed Urgently Wed, 20 October 2004 05:14 Go to previous messageGo to next message
bobski - have already looked at the carby, and I don't think it is the butterfly, cos it wasn't shaking around.
Have checked the vacuum hoses, and found one cracked. Replaced it but it is still doing it.
Might have to check the manifold gasket though as that could be the problem... one other question, will it still be alright to drive, or will that just compound the problem?
[Updated on: Wed, 20 October 2004 06:00]
cwhelan
Adelaide, Semaphore
Re: 4A-C Help Needed Urgently Wed, 20 October 2004 06:33 Go to previous message
It all depends on what the fault is... Personally, I would
do a good insection to mave sure it isnt anything to do with the cam/ valves, If it isn't this then I'd drive it home to look a lil closer to see what it might be. Check vacuum hoses for leaks, generally if there are leaks in the hoses, they will only open up once the engine is warm. Vaccum hoses show up as fine when they are cold. Check dizy bolt hasn't come loose, check leads are secure, eliminate a spark fault... Check for fuel fault, Fuel pump working fine? Check fuel filter... Is air filter clogged? If its none of those then your going to have to start looking at the engine a lil closer. Those are the first obvious things to look at. There may be a leak in the manifold gasket, no way of really checking this without removing it. Is the head gasket fine, may have blown a hole through one of the sides.. Hopefully not. It will still get you home..
Previous Topic:where can i grab a set of 20 valve extractors from??
Next Topic:1G-GZE Boost Gauge Plumb In
Current Time: Thu Oct 29 08:01:53 UTC 2026
Total time taken to generate the page: 0.0068888664245605 seconds
