Classifieds » Engines, Accessories and other Mechanicals » Semi-wrecking TA-23 (2T & 2TG/E) (Adelaide)
RWDboy
Semi-wrecking TA-23 (2T & 2TG/E) (Adelaide) Tue, 19 October 2004 09:20 Go to next message
I'm partially wrecking the TA-23 I've got, lots of bits to go, here's a list of some of the more important bits.
Reasonably Good Bits
2T block (rusted, needs lots of work) accessories (AC, water pump, fan clutch, fuel pump) still attached, crank in good nick, pistons/conrods still good, pushrods still in (carbon deposits has reduced rusting) sell for ~$100 (make an offer), dizzy incl.
2T head, condition unknown, probable waste, looking for $20
SOLD! 2T-G (w/- pistons) + 88260 head (can confirm this) for sale. Some accessories attached. Condition not known, was bought for $250, make an offer. No 2T-GEU dizzy! Plain points 2T-G dizzy Sad
2T-GEU manifold - good nick (just checking the sensors etc) $75
SOLD!Manual bellhousing off of TA-23 not needed anymore make an offer.
SOLD!2 x 40mm Solex Mikunis, really sticky shaft...look in reasonable nick, 32mm chokes $150
SOLD!2 x 40mm Dellortos DHLA, good nick off of Alfa I think, 32mm chokes bought for $300, make an offer
Not so good bits
For all the other bits I have for sale - head over here
[Updated on: Tue, 18 January 2005 01:31]
goonman86
deloraine tas
Re: TA-23 2T 2TG/E bits Tue, 19 October 2004 09:30 Go to previous messageGo to next message
where in aus are you? may be keen on some parts if your close
RWDboy
Re: TA-23 2T 2TG/E bits Tue, 19 October 2004 10:21 Go to previous messageGo to next message
Adelaide Confused
goonman86
deloraine tas
Re: TA-23 2T 2TG/E bits Tue, 19 October 2004 10:31 Go to previous messageGo to next message
well im only over the sea here in tassie.can i have some pics of the 260 2tg. and do you no if it will run. or is it rooted
goonman86
deloraine tas
Re: TA-23 2T 2TG/E bits Tue, 19 October 2004 10:32 Go to previous messageGo to next message
roadrunner
Hornsby, Sydney
Re: TA-23 2T 2TG/E bits Tue, 19 October 2004 10:54 Go to previous messageGo to next message
does the 2t head have screw in plug things underneath the exhaust ports?
can you please pm me your phone number.
RWDboy
Re: TA-23 2T 2TG/E bits Fri, 22 October 2004 02:13 Go to previous messageGo to next message
goonman86 -> freight is pretty expensive to Tassie, I'll put pics up a bit later today...from vague inspection the 2TG is fine (could probably use a rebuild)...however it doesn't come with intake/exhaust manifold (you can buy intake manifolds from Redline, although they aren't of high quality IMHO) exhaust manifolds can be had from any good exhaust shop, and you'll need a set of carbies (I dunno if I have a suitable linkage though) or you can grab my GEU manifold (although that doesn't come with ECU).
The Untouchable
Ballarat
Re: Semi-wrecking TA-23 (2T & 2TG/E) (Adelaide) Fri, 22 October 2004 05:26 Go to previous messageGo to next message
u wouldnt happen to have an electronic ignition would u for a 2tg?
RWDboy
Re: Semi-wrecking TA-23 (2T & 2TG/E) (Adelaide) Fri, 22 October 2004 06:11 Go to previous messageGo to next message
haha - no...
goonman86
deloraine tas
Re: Semi-wrecking TA-23 (2T & 2TG/E) (Adelaide) Fri, 22 October 2004 07:03 Go to previous messageGo to next message
well ive got every thing here we got 40mm webbers and manifold dizzys evey where gear boxs all the geu heads even a god dam 262 head but i might be after an efi manifold
Jonny2TG
Tasmania
Re: Semi-wrecking TA-23 (2T & 2TG/E) (Adelaide) Fri, 22 October 2004 09:03 Go to previous messageGo to next message
I will buy the 2x 40mm Solex Mikuni carbs. If they have linkages that would be great.
$150 plus postage. PM me and we can swap details.
RWDboy
Re: Semi-wrecking TA-23 (2T & 2TG/E) (Adelaide) Fri, 22 October 2004 15:21 Go to previous messageGo to next message
Sold to the man in the red hat...err...Johnny2TG.
I checked for those linkages, couldn't find them Sad Sad Sad It's just your average cable set up, I'll knock $10 off for ya...sent you PM.
(edit)misleading typo!(/edit)
[Updated on: Fri, 22 October 2004 15:22]
cwhelan
Adelaide, Semaphore
Re: Semi-wrecking TA-23 (2T & 2TG/E) (Adelaide) Mon, 25 October 2004 05:29 Go to previous messageGo to next message
Hey there, want to PM your details to me, I can come and look at the bits tonight if you like, that way we can come to some kind of arrangement also.. Thanks mate..
greenta22
Dandenong Ranges, VIC
Re: Semi-wrecking TA-23 (2T & 2TG/E) (Adelaide) Mon, 25 October 2004 13:48 Go to previous messageGo to next message
if you want to seperate the throttle cable from the carbs for whatever reason, i'll take it.
RWDboy
Re: Semi-wrecking TA-23 (2T & 2TG/E) (Adelaide) Wed, 27 October 2004 06:15 Go to previous message
Don't have any throttle cable unfortunately Sad
The only thing I got lying around are just the standard 2T linkages, and they are worthless!
Previous Topic:R154 supra 1jzgte gearbox , flywheel brand new 500hp clutch
Next Topic:fs: 32mm external waste gate
Current Time: Thu Nov 19 10:15:36 UTC 2026
Total time taken to generate the page: 0.0083560943603516 seconds
