Toymods » Tech & Conversions » Oil Temp Gauge for 4age
kristian
Oil Temp Gauge for 4age Wed, 02 October 2002 01:30 Go to next message
Hi guys
Has anyone connected an oil temp into a 4age bluetop. Should i buy a mechanical or electrical gauge ?... thnks
haggis
Re: Oil Temp Gauge for 4age Wed, 02 October 2002 05:28 Go to previous messageGo to next message
Oil temp gauges can be difficult to fit to a standard engine as you have to find somwhere to put it in the oil flow! If you have (or are planning to) mount a remote filter kit or an oil cooler, then many of the sandwich plates can accomodate temp and preasure senders. Ther are companys that make a sandwich plate (goes between the filter and the block) so you can add in temp and preasure senders. This might be the easiest (mabey not the cheapest tho) whay to do it.
Personaly, I'd go an electrictronic one for a couple of reasons:
- No chance of an oil leak in the cabin, especialy under presure.
- You can mount the gauge easier as you dont have to worry about routing an oil line
Craig.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Oil Temp Gauge for 4age Wed, 02 October 2002 07:35 Go to previous messageGo to next message
I thought oil temp (or water, or whatever temp) gauges were all electric? If the oil comes up to the gauge, then it would be sensed by the exact same sort of sensor that could be mounted remotely.
Hey, & having the oil come to the gauge wouldn't work unless there was a return line & it was circulating anyway, so there you go, they're all electric.
Most oil temp gauges I've seen (which isn't many) have a sensor that screws in & replaces the sump plug.
[Updated on: Wed, 02 October 2002 07:35]
GIN51E
Berowra-Sydney
Re: Oil Temp Gauge for 4age Wed, 02 October 2002 09:00 Go to previous messageGo to next message
there are many mechanical guages i find them better, oil pressure guage uses a pipe which the preassure flows through to the guage, engine temp "water" guage has a capilary which is full of some sort of gas which expands depending on heat and moves the needle in the guage sure oil temp guage would use the same effect,
i took the water temp guage and stuck the end in boiling water and it went instantly to 100'C so i can say that they are acurate.
DAMO
MELBOURNE
Re: Oil Temp Gauge for 4age Wed, 02 October 2002 09:48 Go to previous message
VDO sell sump plugs that are actually temp probes which are electric. When you change the oil just unplug(1 wire). Cheap and easy.
Previous Topic:To TVIS or not to TVIS....
Next Topic:driving lights
Current Time: Mon Oct 26 20:17:51 UTC 2026
Total time taken to generate the page: 0.0066080093383789 seconds
