Toymods » Tech & Conversions » ARRRGG 1jz Fuel cut deffender help!!
tyottsoarer
Gold Coast
icon8.gif  ARRRGG 1jz Fuel cut deffender help!! Wed, 20 October 2004 03:36 Go to next message
http://www.option1garage.com.au/images/p7230009.jpg
Was wondering if anyone could tell me how well this unit will work on a JZZ30 soarer. I've had mixed feedback from people I've talked to.
Any help would be good. Very Happy
[Updated on: Thu, 28 October 2004 11:54]
Chris Davey
sunny coast, qld
Re: fuel cut deffender Wed, 20 October 2004 03:44 Go to previous messageGo to next message
from what i have read there are two types. One that will disable boost cut altogether and one that will raise it a little. if you are buying one to stop hitting boost cut, then it is a good idea, but if you are buying it to run big boost it isn't a good idea as the MAP sensor only reads to 1bar.
tyottsoarer
Gold Coast
Re: fuel cut deffender Wed, 20 October 2004 03:52 Go to previous messageGo to next message
I see , this is just to get rid of boost cut , its gonna be run with an avcr and safc II. I don't think i mentioned its auto, does that make a difference?
Chris Davey
sunny coast, qld
Re: fuel cut deffender Wed, 20 October 2004 04:09 Go to previous messageGo to next message
shouldn't as it just gets wired to the MAP sensor as far as I am aware.
also, do a search on 40c fuel cut defender as there was a huge discussion about them a while back.
MR 1JZ
Re: fuel cut deffender Wed, 20 October 2004 04:29 Go to previous messageGo to next message
Chris Davey wrote on Wed, 20 October 2004 13:39
i just did a search and came up with fuggal? Sad
davedave
Re: fuel cut deffender Wed, 20 October 2004 05:03 Go to previous messageGo to next message
This unit seems to have 4 wires, but maybe yours grounds itself when you mount it (and hence no black wire)
http://www.hksusa.com/info/download.asp?id=1793#
ae95
Re: fuel cut deffender Wed, 20 October 2004 05:10 Go to previous messageGo to next message
im pretty sure the apexi rsm remove all cuts
ie. boost cut and speed cut
ae95
Re: fuel cut deffender Wed, 20 October 2004 05:48 Go to previous messageGo to next message
my bad
it only removes speed cut
Chris Davey
sunny coast, qld
Re: fuel cut deffender Wed, 20 October 2004 05:52 Go to previous messageGo to next message
try "fcd" in search Smile
tyottsoarer
Gold Coast
Re: fuel cut deffender Wed, 20 October 2004 06:42 Go to previous messageGo to next message
the other fuel cut threads title has "1JZ fuel cut" in it , just search for that. Yeah i saw there as no earth wire maybe its just not visible in the photo. Does anyone know if this unit raises the cut level or eliminates it? It looks like it has a winder on it.
ae95
Re: fuel cut deffender Wed, 20 October 2004 06:48 Go to previous messageGo to next message
im pretty sure you can raise the cut level or cut it completely
tyottsoarer
Gold Coast
Re: fuel cut deffender Wed, 20 October 2004 07:01 Go to previous messageGo to next message
http://www.mr2.com/ARTICLE/HKSFCDat.html
very helpful article, It mentions settings on the fcd so he must be using a newer version with pre-determind leves. The one I have just turns to raise cut level i guess, making it adjustable
MR 1JZ
Re: fuel cut deffender Wed, 20 October 2004 07:04 Go to previous messageGo to next message
yeah i found it cheers Very Happy
doesnt really help as im not the biggest tech head there is and it doesnt really explain how to do it for an AFM car, however if someone figues it out (/me looks in JCMF's direction) ill gladly take some instructions off thier hands and throw them a nice crisp $20 note Very Happy
davedave
Re: fuel cut deffender Wed, 20 October 2004 22:22 Go to previous messageGo to next message
Try downloading the pdf on this page http://www.hksusa.com/info/download.asp?id=1793#
It explains how to do it (which is relevant to cars with an AFM). As far as I know AFM cars still have a map sensor (or sometimes called a boost sensor) as they need this to control fuel cut etc, they just don't use it for fuel maps.
tyottsoarer
Gold Coast
Re: fuel cut deffender Fri, 22 October 2004 01:32 Go to previous messageGo to next message
http://img61.exs.cx/img61/8462/DSC05386.jpg
The thing has arrived, I've looked around for installation instructions relative to MAP sensored cars as its goin on a 1JZ.
DAVEDAVE, it does have a black wire just wasnt visible in the other photo. Does anyone have any experiance fitting these on an engine similar to mine?
Any help would be appreciated.
Re: fuel cut deffender Fri, 22 October 2004 02:40 Go to previous messageGo to next message
Looks similar to the VFCC I installed on my 2JZ... little black box with 4 wires sticking out. One for +12v (probably the red wire), one for earth (probably the black), one for MAP signal in and one for MAP signal out. You're going to have problems wiring this thing up if you don't know which wire is which, although I suppose you could try the trial-and-error method!
Chris Davey
sunny coast, qld
Re: fuel cut deffender Fri, 22 October 2004 03:03 Go to previous messageGo to next message
I remember seeing on Manny's site a diagram of how to install them. I have it downloaded at home but I am at work ATM. Don't know the site unfortunately Sad
tyottsoarer
Gold Coast
Re: fuel cut deffender Fri, 22 October 2004 11:17 Go to previous messageGo to next message
Chris Davey wrote on Fri, 22 October 2004 13:03
If you could find that it'd be a great help, if you have it downloaded could you possibly email it to me? at skullomaniatheone@hotmail.com really, really appreciate it if you could thanks
davedave
Re: fuel cut deffender Fri, 22 October 2004 13:16 Go to previous messageGo to next message
davedave wrote on Thu, 21 October 2004 08:22
I don't know why I'm quoting myself, I'm by no means an expert on the matter.... But I don't think there'd be a difference between an AFM or MAP installation. Both need to report the Manifold Absolute Pressure back to the ecu, you just need to intercept that wire with your FCD. The HKS downloadable manual on that link I mentioned explains it.
The important bit:
Connect the red wire to a power source
Connect the black wire to a ground source
Cut pressure sensor or air flow signal wire. Connect the yellow wire to the wire going to the factory ECU. Connect the white wire to the wire going away from the ECU.
Logic tells me that you wouldn't connect it to the AFM as the FCD just alters the signal being sent, and I don't think you want your car thinking it is getting less air flow. I'd be finding the MAP sensor and using that.
Acutally, for cars that don't have an AFM. Wouldn't the FCD tricking the car in to thinking it has less boost than it does, cause it to lean it out? Can someone who knows what they're on about please speak up Smiley =
tyottsoarer
Gold Coast
Re: fuel cut deffender Fri, 22 October 2004 13:21 Go to previous messageGo to next message
thanks a lot for the help i have a fair idea of what to do now , but anyone with other ideas are welcome
tyottsoarer
Gold Coast
Re: fuel cut deffender Thu, 28 October 2004 11:52 Go to previous messageGo to next message
ARGGGG
I have found a ECU pin out thing and to my surprise there are 3 map sensors signals going to the ECU whcih one do i use the FCD on ? I'm very confused
Confused
HedgehogSandwich
UK
Re: ARRRGG 1jz Fuel cut deffender help!! Sun, 31 October 2004 20:42 Go to previous messageGo to next message
You cant raise the fuel cut level on the 1JZ., you can only remove it.
The 1JZ fuel cut level is *just* beow the voltage limit of the map. this means that there is no headroom left for the FCD to raise cut to.
So, dont expect to raise it, just remove it.. and have no safety cutoff left Very Happy
Anthony Kellam
Re: ARRRGG 1jz Fuel cut deffender help!! Sun, 31 October 2004 22:17 Go to previous messageGo to next message
tyottsoarer, you want to intercept the wire called PIM on the loom (usually light green or light green/red trace).
Hedgehog, An FCD never takes the ECU into "further mapping", it's not about that. It simply clamps the output voltage of the MAP sensor or AFM so it cant go above (or below) a preset voltage. As boost passes this preset point (say 14 psi) the ECU will keep supplying fuel for this level.
On most cars tuning is OK because things are already a little rich by default and as the exta boost raises fuel pressure the injectors pass more fuel for a given opening time, thus keeping an upward trend in fuel delivery.
Clearly, its a little hit and miss and things can be made better with a rising rate fuel pressure reg. But the important thing to remember is that an FCD "clamps" the ECU at what it thinks is a safe level, it does not unlock any higher tuning maps....
HedgehogSandwich
UK
Re: ARRRGG 1jz Fuel cut deffender help!! Mon, 01 November 2004 08:32 Go to previous message
Anthony Kellam wrote on Sun, 31 October 2004 22:17
yes i know, that isnt what i was saying. I was saying that you cant *raise* the fuel cut level on the 1JZ with an FCD that has a raised fuel cut feature.
eg on the 2JZ you can raise the fuel cutpoint, as the fuel cut on the 2JZ is about 4.3 volts, so you still have 0.7 volts left to trigger an overboost fuel cut with the right FCD. However, you cant do this on the 1JZ system because stock fuel cut is near the limit of the map sensor ie about 4.9 volts,leaving very little voltage range left in order to a secondary overboost cutoff.
[Updated on: Mon, 01 November 2004 08:40]
Previous Topic:AE86 RCA Install
Next Topic:Serpentine Belt Tensioners
Current Time: Sun Oct 18 20:04:15 UTC 2026
Total time taken to generate the page: 0.0083181858062744 seconds
