Toymods » Tech & Conversions » New clutch for Celica GT4 ST185??
zasa
New clutch for Celica GT4 ST185?? Wed, 20 October 2004 23:53 Go to next message
Hi Guys.
A few days ago I posted about an issue I have with my car. Basically, shifting from 1st to 2nd gear and vice versa requires a bit of effort. Sometimes it goes in fine, sometimes it's a little sticky to shift between those gears.
Anyways, I took the car to a mechanic friend yesterday. He thinks that the clutch is about to go (still using the original after 183,000k's). He said there was nothing wrong with the box, and the sticky shifting was a result of a worn clutch, that no longer engages as it should. Any opinions on his analysis?
I was looking around for a clutch kit to suit my car. I came accross the Exedy heavy duty kit, and the Sports Ceramic kit. Are these good? Which one should I go for (what are the benefits etc)? What should I expect to pay for the clutch kits?
Thanks.
[Updated on: Thu, 21 October 2004 00:04]
wagonist
Toymods Club Treasurer
Re: New clutch for Celica GT4 ST185?? Thu, 21 October 2004 01:58 Go to previous messageGo to next message
I have an ST205 factory clutch, flywheel & pressure plate sitting at home which I may be convinced to let go of.
If you still have the factory clutch at 183 000km, you must either drive it like a granny, or you actually know how to drive an all wheel drive properly.
I've heard that the uprated 205 clutches aren't worth much salt as it increase the pressure on the gearbox, dunno bout 185 versions though.
Due to the all wheel drive nature of the GT4, you need a weak point in the drivetrain. Normally thats the friction between the tyre & road on a 2wd, but can't do it on a 4wd, so the clutch is that weak point instead. Its designed to be a wearable part that's "relatively" easy to change.
zasa
Re: New clutch for Celica GT4 ST185?? Thu, 21 October 2004 02:46 Go to previous messageGo to next message
Interesting.
So is an exedy 'too good' for the gearbox?
wagonist
Re: New clutch for Celica GT4 ST185?? Thu, 21 October 2004 02:50 Go to previous messageGo to next message
Seeing as your standard one lasted so long, I would guess that you could have a better clutch without it causing problems with breakages.
WRX's have gearbox problems because of the button clutches & high rpm dumps that people do, no other reason. I imagine its the same with AWD Toyotas.
Not experienced with AWD Toyotas so I couldn't answer your question bout the Exedy, but I've heard the TRD item isn't worth the money.
zasa
Re: New clutch for Celica GT4 ST185?? Thu, 21 October 2004 02:57 Go to previous messageGo to next message
Well that makes perfect sense to me.
What's your opinion on the sticky 1st and 2nd gears? Do you think there is a relationship with a worn clutch?
RAV-GT4
Toymods member
Rydalmere, NSW
Re: New clutch for Celica GT4 ST185?? Thu, 21 October 2004 03:29 Go to previous messageGo to next message
wagonist wrote on Thu, 21 October 2004 11:58
Steve, I have an organic clutch with my ST205 gearbox. How long would one of these typically last, "sensible" driving conditions? Rolling Eyes
What kinds of clutch ARE good with the ST205 gearbox?
(Sorry to thread-hijack.. Evil or Very Mad)
JustenGT4
Re: New clutch for Celica GT4 ST185?? Thu, 21 October 2004 03:50 Go to previous messageGo to next message
Come on, who has EVER broken a GT4 gearbox that was well maintained and setup correctly?? Zippo.
An uprated clutch is a must if you want to put power to the ground on launches and trust me you won't break the drivetrain. If your car is only lightly modded then a 205 setup will do the job nicely...they are a good clutch straight from factory. Some exedy setups are great others not worth the cash so talk to someone who knows the product to get good value.
If you can wrangle trade as i do a 205 clutch kit is only $180 which is great value. Labour costs to fit are the killer.
I've run more gearbox and clutch combos than anyone i know so pick a power level and i'll tell you what i ran that worked.
RAV-GT4
Toymods member
Rydalmere, NSW
Re: New clutch for Celica GT4 ST185?? Thu, 21 October 2004 03:58 Go to previous messageGo to next message
Ok, so typically you set it up to work to the hardest conditions you want to put it through right?
Say if you want to do occasional ¼-mile times and the rest of the time like normal street use. If you want a clutch that's strong but won't break off your left foot to operate?
spectral
Re: New clutch for Celica GT4 ST185?? Thu, 21 October 2004 05:10 Go to previous messageGo to next message
I can vouch for the ST205 clutch as well. I'm only putting out moderate power (around 175Kw or so) and its fine, no slips after many hard drag launches.
I'm currently rebuilding my engine and am looking at around 230Kw and the end, and will probably stick with the ST205 unit until it starts to wear out.
JustenGT4
Re: New clutch for Celica GT4 ST185?? Fri, 22 October 2004 02:14 Go to previous messageGo to next message
That's pretty much right. The 205 clutch is very user friendly on the left leg, that's what it sounds like you should use
JustenGT4
Re: New clutch for Celica GT4 ST185?? Fri, 22 October 2004 02:18 Go to previous messageGo to next message
230kw at the wheels will toast a 205 clutch 1st launch. I have a tad less and toasted a twin plate organic in around 10K. Had to go to a twin plate button to get no slip and therefore reduce wear.
wagonist
Re: New clutch for Celica GT4 ST185?? Fri, 22 October 2004 02:33 Go to previous messageGo to next message
sorry dude:
Ask Turbo_Caldina how he broke his bellhousing in his ST195 Caldina with ST185 running gear.
KYOTO
Re: New clutch for Celica GT4 ST185?? Fri, 22 October 2004 02:44 Go to previous messageGo to next message
Perhaps you could tell us and save us the hassle? Very Happy
spectral
Re: New clutch for Celica GT4 ST185?? Fri, 22 October 2004 02:48 Go to previous messageGo to next message
JustenGT4 wrote on Fri, 22 October 2004 12:18
Nah, 230Kw at the flywheel approx. I don't have deep enough pockets for 230Kw at the wheels Smile So lets say 160-170Kw at the wheels.
wagonist
Re: New clutch for Celica GT4 ST185?? Fri, 22 October 2004 03:01 Go to previous messageGo to next message
One clutch dump off the line too many with a button clutch.
JustenGT4
Re: New clutch for Celica GT4 ST185?? Fri, 22 October 2004 04:22 Go to previous messageGo to next message
A bell housing is not a gearbox, i'd bet money that there was some other issue that caused that failure albeit the final clutch dump was the catalyst.
There are a alot of big hp cars out there experiencing good reliability not to mention a heap of competition cars.
A GT4 box failure is by far the exception and not the rule as say for a WRX. If you're talking a GrpA or 205 box then even more so.
I have no qualms putting 400hp flywheel thru a stock box and driveshafts with the only consideration being a good quality fully synth gear oil.
wagonist
Re: New clutch for Celica GT4 ST185?? Fri, 22 October 2004 04:29 Go to previous messageGo to next message
True, it was just the bellhousing. The gears survived intact.
I still think you should leave the clutch as a weak point in the 4wd drivetrain. Its the easiest to replace in terms of availability, etc
zasa
Re: New clutch for Celica GT4 ST185?? Fri, 22 October 2004 04:39 Go to previous messageGo to next message
Anyone know if it is possible to fit a ST205 clutch kit straight into a 185??
I just got some quotes for both clutch kits, the 185 is far more expensive (205:$225, 185:$600!! Shocked) . Naturally I would go for the 205 as it is cheaper, and better from what i've been told.
JustenGT4
Re: New clutch for Celica GT4 ST185?? Fri, 22 October 2004 04:55 Go to previous messageGo to next message
Yup 205 kit is a straight bolt in the 185.
Wagonist, yes you need a fuse or you just replace bits as they break...fact of life if you want to go fast.
zasa
Re: New clutch for Celica GT4 ST185?? Fri, 22 October 2004 04:58 Go to previous messageGo to next message
SWEET!!!!!! Very Happy
I will order one from toyota today!
Puffy
Re: New clutch for Celica GT4 ST185?? Fri, 22 October 2004 13:18 Go to previous messageGo to next message
Group A box's are bomb proof. It wont be long before wrx's try to use them Laughing . I have used harsh brass button 3 puck clutches and the only thing I have managed is to re sculp some interesting pressure plates.
Its your syncros or pressure plate not your clutch. Clutches slip.... pressure plates and gear syncros is what crunches.
zasa
Re: New clutch for Celica GT4 ST185?? Sun, 24 October 2004 23:05 Go to previous messageGo to next message
I just rang Neal Bates auto in Hume, Canberra.
I asked how much it would cost to get the new clutch fitted. I was quoted $1800 for 20 hours work Shocked , as I was told that the engine and gearbox have to be removed.
Is this right?
Draza
Wahroonga
Re: New clutch for Celica GT4 ST185?? Sun, 24 October 2004 23:13 Go to previous messageGo to next message
To fit a new clutch to the GT4 the engine and gearbox have to be removed, i don't know if that labour is rite as i'm not a mechanic.
zasa
Re: New clutch for Celica GT4 ST185?? Sun, 24 October 2004 23:17 Go to previous messageGo to next message
I got another quote for $850. But it sounded like this place had never done this sort of work before.
Damn, I never thought it would be this costly Crying or Very Sad
davedave
Re: New clutch for Celica GT4 ST185?? Sun, 24 October 2004 23:30 Go to previous messageGo to next message
The engine has to be removed as well, wow, that's f*cked up. I thought axles out, mounts off and unbolt it from the engine and transfer case, but I'm quite often wrong Smiley =.
Is there an online BGB for the ST185 anywhere?
Here's a 91 mr2 one anyways, I thought it would have been similar to this?
MR2 online BGB
Pulling out the MR2 Tranny
zasa
Re: New clutch for Celica GT4 ST185?? Sun, 24 October 2004 23:33 Go to previous messageGo to next message
Well I had a look at my Chilton's manual, and maybe I didnt look hard enough but I didnt come accross and engine removal. I'm not very happy
Draza
Wahroonga
Re: New clutch for Celica GT4 ST185?? Sun, 24 October 2004 23:43 Go to previous messageGo to next message
Yea u can't get the box off with out dropping it down a little bit, so with hoist on hand it would be easy.
davedave
Re: New clutch for Celica GT4 ST185?? Mon, 25 October 2004 00:03 Go to previous messageGo to next message
ahhh, yep, that's a whole lot of difference to removing the engine. Every clutch I've done I've had to do that.
With most of the mounts off (3 of them are on the gearbox aren't they), you shouldn't have too much problem lifting or jacking the front of the engine up to get the right angle to remove/replace the gearbox.
If you've got a mate that's willing to lend a hand and get his hands dirty, it's usually not too hard a job. If it was me, I'd be trying to save myself $1500 and having a crack at it myself. Anyone know of any ST185 gotchas that would prove my advice to be bad?
Grab yourself an alignment tool as well, unless you like doing the gearbox shuffle Smiley =.... that said, I've never used one myself and only found out about them recently. It's a good workout on the arms without it though Laughing
Edit: damn pretend html tags
[Updated on: Mon, 25 October 2004 00:04]
zasa
Re: New clutch for Celica GT4 ST185?? Mon, 25 October 2004 00:20 Go to previous messageGo to next message
I've rang a few other places, ranges from $750 to $1000. Even Toyota said around the $1000 mark, so I dont know where this Neal Bates place is coming from.
spectral
Re: New clutch for Celica GT4 ST185?? Mon, 25 October 2004 04:10 Go to previous messageGo to next message
Welcome to owning a GT4.
Unless you can do most (if not all) the work yourself, these cars are a money pit.
As Justen already told you earlier in the thread, the labour costs are the expensive part of this repair, not the clutch iteself.
My gearbox/clutch was swapped with the engine still in the car, but obviously supported properly or else the thing will remove itself from the engine bay without consultation Smile
If you aren't in a hurry.. I'd put that $1000 towards and engine crane , jack stands, trolley jack and a good tool kit. Have a go. You may suprise yourself, either way you'll definitely learn a lot.
If you are in a hurry, then bend over $$$ wise, cause as you've discovered, the workshops charge hefty amount per hour.
zasa
Re: New clutch for Celica GT4 ST185?? Mon, 25 October 2004 04:28 Go to previous messageGo to next message
I've managed to find a place that will do it for $650. I have to wait for 3 weeks until I take it in into the shop. I guess that's not bad, it beats paying $1000+
I'd love to do it myself, I just don't have the time. The most I've ever done is change a water pump on an old Cortina. So I dont have the confidence to do this sort of job myself.
[Updated on: Mon, 25 October 2004 04:34]
spectral
Re: New clutch for Celica GT4 ST185?? Mon, 25 October 2004 04:45 Go to previous messageGo to next message
I'd get that quote in writing before getting them to start... or else expect that phone call when they realise the extent of the work required. Sure they know its a GT4, not a regular Celica?
Most shops charge out at about $65 per hour.. so thats only 10 hours work. Thats a bloody quick clutch/gearbox change on a GT4.
zasa
Re: New clutch for Celica GT4 ST185?? Mon, 25 October 2004 05:19 Go to previous message
I was advised of that already by Justen Smile (the quote on paper)
Pretty much all the places I spoke to, first checked their manuals to quote number of hours etc. The GT4 came up as 8-10 hours.
The only place that quoted any different was neal bates auto. They quoted 20 hours +, at $1800 all up. That guy said the entire engine/gearbox needed to be removed.
So either the 10 or so places that quoted 8-10 hours made a mistake (even though the specifically listed the GT4, and one of these places includes Toyota) or Neal Bates likes to do things the hard, expensive way.
Previous Topic:MA70 Tail Light Warning, I think
Next Topic:wierd aircon problem (91 lux)
Current Time: Wed Oct 14 01:54:35 UTC 2026
Total time taken to generate the page: 0.040187120437622 seconds
