Toymods » Tech & Conversions » Ra40 + 1JZ-GTE
Jarvis
Ra40 + 1JZ-GTE Thu, 21 October 2004 02:14 Go to next message
Hi guys, am looking for any concrete info on 1J's into Ra40's.
Now before this turns into a slagging match over ra40's or 1G alternatives, i have done a search and each thread seems to turn into that.
What i'm after is anyone who has any info or advice that is reliable or concrete about the conversion. anything at all. seeing how the car only weighs 1100kgs my plan is a stock 1J, intercooler, manual w58 box and lsd rear end and I already have the w58. I don't want to go the 1g-gte route and this will be my first conversion but one that will last. I know if i put a 1g-gte in it i'll only end up putting a 1J in later. Handling etc isn't of major concern and i don't think it make that much difference with a good suspension setup as it will be mainly a weekend warrior.
thanks for any info
Jarvis n Razz
P.s for anyone looking for info later there is a mediocre article in ZOOM Issue 43, 1J into Ra40 by RPM, good for pictures but....????
barned01
Re: Ra40 + 1JZ-GTE Thu, 21 October 2004 09:11 Go to previous messageGo to next message
Yeah i know how you feel i have been tossing this conversion up for ages and am slowly upgrading the car with whatever money i can scrounge up before the engine upgrade itself (diff, brakes fuel, chassis strength etc.).
Although i am interested, my intrest lies in a 1uz conversion i think they are around the same weight and are more compact.
but whatever pops up it would be an interesting read.
Re: Ra40 + 1JZ-GTE Thu, 21 October 2004 09:16 Go to previous messageGo to next message
barned01 wrote on Thu, 21 October 2004 17:11
Actually, a 1UZFE weighs less, it's about the same as a 1GGTE. As for this conversion, from memory there was something about the twin-turbo engine that I think fouled on the steering, and the only person who I was speaking about it to was considering a vvti 1JZGTE for that very reason.
munki
Gold Coast
Re: Ra40 + 1JZ-GTE Thu, 21 October 2004 09:20 Go to previous messageGo to next message
rack and pinion is needed or it wont fit and you need handleing or you will put yourself into a tree and it will not be engineered without upgrades in this area.
my guesstimation is that you will need in excess of $15000 to do this conversion.
[Updated on: Thu, 21 October 2004 09:21]
drift86levin
brisvegas
Re: Ra40 + 1JZ-GTE Thu, 21 October 2004 10:29 Go to previous messageGo to next message
are you sure about the steering??? isn't the RA40 setup the same as the RA28/23 setup?? cos if it is..my mate who owns an RA23 with a big single turbo has no problem..ohh wait i just answerd my own question..custom turbo manifold etc so it clears..don't mind me!... belive me it's frightfully fast!!! Very Happy
rob_RA40
c'town, NSW
Re: Ra40 + 1JZ-GTE Thu, 21 October 2004 13:22 Go to previous messageGo to next message
munki wrote on Thu, 21 October 2004 19:20
soz dude but your wrong about the rack and pinion
both TT and VVTi will go in without having to do a rack and pinion conversion, the TT u have to shave some meat off the rear turbo hosuing and the VVti well that fits sweet as AND its even easy to get to the oil filter for a service.
Daniel the CD is in the mail along with the alarm key and little rubber boot that goes on the terminal sticking out of the diagnosis box.
as for the rest get some MS65 crown hubs peugeot discs hilux calipers and RT132 struts and u have your front end done
then hilux diff in rear
unfortunately after that the weak point will be your gearbox Shocked
Daniel i have a chromoly 1JZ ---> W58 flywheel for sale (if glenn [blacksupra] doesnt want it) as i said when u were looking to buy the car, 1JZ vvti was the plan before i pulled the plug...
if u want, gimmie a call sometime ill step u through EVERYthing i picked up researching this conversion.
have a good one
BlackSupra
Re: Ra40 + 1JZ-GTE Thu, 21 October 2004 23:16 Go to previous messageGo to next message
i want it Cool
Jarvis
Re: Ra40 + 1JZ-GTE Fri, 22 October 2004 02:14 Go to previous messageGo to next message
YEAH WELL I ALREADY GOT A ENGINEER TO SAY YES TO THE CONVERT. NATURALLY HE WANTS UPGRADED BRAKES, DIFF AND AS FOR SUSPENSION HE SAID STICK SOME STIFFER SPRING IN AND SET YOU CAMBER ETC RIGHT AND HE'D BE HAPPY!! HE EVEN SAID THAT FOR HIM SCOLLOPING THE FIREWALL WASN'T A BIG DEAL AND IF IT LOOKED FACTORY HE'D OK IT. I DIDN'T THINK THE STEERING ENTERED INTO IT BUT THANKS FOR YOUR THOUGHTS ANYHOW. IT'S REALLY THE LITTLE THINGS THAT ARE HELPFUL, YOU KNOW THE BITS THAT DON'T QUITE FIT HERE OR ARE AT THE WRONG ANGLE THERE. KEEP SLINGING THE INFO MY WAY AS YOU GET IT GUYS.
HEY ROB IF SUPRAMAN DOES BUY THAT FLYWHEEL LET US KNOW PLUS WHATS THE GO WITH THAT CROSSMEMBER YOU SPOKE OF??? WHAT DID IT COME OUT OF AND WHAT IS DIFFERENT ABOUT IT FROM STANDARD????
CHEERS
JARVIS Very Happy
Chris Davey
sunny coast, qld
Re: Ra40 + 1JZ-GTE Fri, 22 October 2004 02:16 Go to previous messageGo to next message
talk to Skidman as he used to own an ra40 with a manual 1jz in it.
Re: Ra40 + 1JZ-GTE Fri, 22 October 2004 02:34 Go to previous messageGo to next message
Wasn't that an RA60?
rob_RA40
c'town, NSW
Re: Ra40 + 1JZ-GTE Fri, 22 October 2004 02:41 Go to previous messageGo to next message
glenn are u gonna contact me about the fly bra? PM me ill give u my number.
skidman owned a RA60 which has rack and pinion and is different from RA40
Dan the crossmember is from a TT132 corona. it is a rear sloping xmember that will allow u to run a front sump VVti 1JZ out of a JZX100 chaser.
im only 99% sure it will fit at the moment but a bit of measuring should show us if it will or not.
Chris Davey
sunny coast, qld
Re: Ra40 + 1JZ-GTE Fri, 22 October 2004 02:46 Go to previous messageGo to next message
Norbie wrote on Fri, 22 October 2004 12:34
whoops Embarassed
maybe? I don't know the old celica models too well Razz
rob_RA40
c'town, NSW
Re: Ra40 + 1JZ-GTE Fri, 22 October 2004 03:14 Go to previous message
no wuccas bra Cool
Previous Topic:Hilux 22R to 22r-e or better
Next Topic:ABS switch
Current Time: Tue Oct 20 01:06:54 UTC 2026
Total time taken to generate the page: 0.0065300464630127 seconds
