Toymods » Tech & Conversions » 2jzge trigger wheel on crank?
BlackSupra
2jzge trigger wheel on crank? Thu, 21 October 2004 05:41 Go to next message
Sitting on the end of the crank behind the pulley i 'had' a metal circle with numerous holes drilled into the outer edge of the circle, all the way around the circumfrence.
Now i was of the understanding that the GE doesnt use a crank trigger or pickup, however this circle looks like it would be apart of a trigger setup of some description.
Basically it was lunched when i removed the pulley, don't think i really need one, but thought i would ask never the less.
ta guys.
BlackSupra
Re: 2jzge trigger wheel on crank? Thu, 21 October 2004 05:48 Go to previous messageGo to next message
hmm a little more searching and apparently im talking about the 'timing belt guide'
http://www.mkiv.com/manual/manualtt/timing_belt_replacement/tbr2.jpg
EVOSTi
cambo
      no
Re: 2jzge trigger wheel on crank? Thu, 21 October 2004 09:22 Go to previous messageGo to next message
its not a crank trigger, its a ring that helps keep the timing belt on the gear.
when the crank pulley is tightened on, the belt guide is butted up against the timing gear and prevents the timing belt from coming off the edge and rubbing against the cover and eventually breaking or coming off.
BlackSupra
Re: 2jzge trigger wheel on crank? Thu, 21 October 2004 11:56 Go to previous messageGo to next message
ta, this was the conclusion i came to as well, thanks!
Re: 2jzge trigger wheel on crank? Thu, 21 October 2004 13:41 Go to previous messageGo to next message
I'll take a pic of the trigger wheel on the VVTi 2JZGE I have lying around here and post it up over the weekend.
BlackSupra
Re: 2jzge trigger wheel on crank? Thu, 21 October 2004 23:19 Go to previous messageGo to next message
Gotta love just having a VVTi engine 'lying around'.
Shocked Shocked Shocked I just noticed the 'Z' in your signature!!!
[Updated on: Thu, 21 October 2004 23:20]
Re: 2jzge trigger wheel on crank? Thu, 21 October 2004 23:28 Go to previous message
Very Happy
will post later this arvo
Previous Topic:Ideal operating temp for a 7M-GTE?
Next Topic:4AGE problems - help needed Please!!!
Current Time: Sun Oct 18 17:51:36 UTC 2026
Total time taken to generate the page: 0.019351005554199 seconds
