Toymods » Tech & Conversions » 1JZGTE Belt
KOFFEE-BLACK
1JZGTE Belt Thu, 21 October 2004 06:43 Go to next message
Hey guys,
As you probably notice by now, im not very "mechanical" minded, but If I wanted to change the belt that controls the water pump, alternator etc, would it be a hard job? Is there only the 1 belt, that controls all? Mine has alot of fine craks, this obviously means change it right?
Danish
Re: 1JZGTE Belt Thu, 21 October 2004 07:19 Go to previous messageGo to next message
Accessory belt, shouldn't be too hard to change. Get a genuine belt from Toyota and give it a go. Make sure you don't puncture your radiator while your doing it though, cover it up. You'll have to loosen one of the pulleys to get it on i think.
BlackSupra
Re: 1JZGTE Belt Thu, 21 October 2004 07:40 Go to previous messageGo to next message
i think there are two different sizes for 1jz's depending on what model it came from. But toyota printed part numbers on the belt Smile
Very easy job.
KOFFEE-BLACK
Re: 1JZGTE Belt Thu, 21 October 2004 07:53 Go to previous messageGo to next message
Thanks guys, its the earlier non VVTi model.
Puncture the radiator??? How would one manage that?
Danish
Re: 1JZGTE Belt Thu, 21 October 2004 07:55 Go to previous messageGo to next message
Trying to get a pulley off with tools, very easy to do.
BlackSupra
Re: 1JZGTE Belt Thu, 21 October 2004 08:19 Go to previous messageGo to next message
dont take any pulleys offffffff!!
Here is a pic scammed from danish's conversion
http://www.users.bigpond.net.au/soarer/1jzengine/1JZFront.jpg
Pulley in the middle, just above the crank pulley is actually a tensioner. Pop a bar with a 14mm fitting on it and leverage it to the left.
Install belt, then let the tensioner take up the tension.
easy.
Danish
Re: 1JZGTE Belt Thu, 21 October 2004 08:20 Go to previous messageGo to next message
Easy as, my 5 second memory is awesome. It's my own picture too.
Skip
Re: 1JZGTE Belt Thu, 21 October 2004 08:44 Go to previous messageGo to next message
I made a tool that grabs the tensioner out of aluminum. THE_WITZL would be proud of it, maybe i should post it up? Smile
Danish
Re: 1JZGTE Belt Thu, 21 October 2004 09:31 Go to previous messageGo to next message
Yeah post it up!
Bentt
Re: 1JZGTE Belt Fri, 22 October 2004 06:24 Go to previous messageGo to next message
only need a socket and ratchet handle...
Put a socket on the tensioner and then force it to loosen enough to slide the belt off it... Remove belt carefully.. don't damage radiator when pulling it over fan blades.. and opposite to put new one on... 10min job...
I have a brand new toyota belt left over if you are chasing one.. they are about $45 from toyota...
Chris Davey
sunny coast, qld
Re: 1JZGTE Belt Sat, 23 October 2004 03:48 Go to previous messageGo to next message
I still have a chuckle when I see all of the pulleys on a stock 1jz. Mine has alternator relocated to inlet side of engine on adjustable bracket, water pump and harmonic balance. Nice and simple Smile
KOFFEE-BLACK
Re: 1JZGTE Belt Sat, 23 October 2004 08:59 Go to previous message
Cool, sounds like I may be capable hehehe.
Bennt, how much do you want the belt for?
Also, noticing something, the pulley, furthest to the right, is about 2mm next to the intercooler piping, with engine fles, will this rub????
Previous Topic:idle speed controller, 7M-GE
Next Topic:7MGTE Oil Filter Removal (got it off!)
Current Time: Wed Nov 18 22:32:30 UTC 2026
Total time taken to generate the page: 0.0063169002532959 seconds
