Toymods » Tech & Conversions » 20v quads vacuum lines
RS1600
20v quads vacuum lines Thu, 21 October 2004 06:59 Go to next message
I have a set of 20v quads and want to know where the 6 vacuum lines off the quads go too.
1 x line on top no.1 throttle body
1 x line on top no.4 throttle body
4 x lines out the bottom of each throttle body.
Where do the lines for the map sensor and fuel pressure regulator come from.
improvedae86
Re: 20v quads vacuum lines Thu, 21 October 2004 12:06 Go to previous messageGo to next message
Ow i think the last one i looked / worked on , was ..
Fuel reg , no 1
Map , no 4
The lower four are the balancing cross overs .
But i guess all this depends on what the set up is on ?
N/A , Turbo , on a 16v head set up , or stock 20v ?
RS1600
Re: 20v quads vacuum lines Thu, 21 October 2004 21:31 Go to previous messageGo to next message
The setup will be on a 16v bigport motor.
improvedae86
Re: 20v quads vacuum lines Thu, 21 October 2004 21:55 Go to previous messageGo to next message
Well thats how i remember setting one up , sorry i couldn't be more help
ae86trueno
Re: 20v quads vacuum lines Thu, 21 October 2004 22:17 Go to previous messageGo to next message
with big cams 288-304 you may just end up blocking them all up thats what i had to do.
The fuel reg on no 1 was pulsing the regulator and throwing out the fuel map, and you dont really have to run map to no 4, just run off TPS and the bottom 4 are for idle air leak, but you can get around this by just opening the throttles slightly
Ben.
demuire
Ipswich
Re: 20v quads vacuum lines Thu, 21 October 2004 22:23 Go to previous message
ae86trueno: So did you end up running the fuel reg on anything? Does the car run alright without signal from the MAP?
Do the SVT throttles also have these (since the SVT is AFM and not MAP)? Or is it only the BLT?
Previous Topic:4AGE problems - help needed Please!!!
Next Topic:is it better to have 4-1 extractors or 4-2-1??
Current Time: Sat Oct 17 19:04:59 UTC 2026
Total time taken to generate the page: 0.0045158863067627 seconds
