Toymods » Tech & Conversions » 1JZ idle speed problem
Milhouse
1JZ idle speed problem Thu, 21 October 2004 11:51 Go to next message
On start up sometimes my 1j will idle a lot lower then normal.
It does not seem to affect running or boosting at all but when you come to a stop it will idle at at least half its normal speed. Then after a while it will go away and idle normally.
Its just annoying because it is like the engine is asleep and as soon as you put your foot on the pedal it wakes up and takes longer to get going if that makes sense.
It is a JZX81 conversion to MX83 Cressida.
Thanks!
mx83toy
Re: 1JZ idle speed problem Fri, 22 October 2004 01:12 Go to previous messageGo to next message
i got a spare idle control valve you can have fairly cheap... pm me
ChuckLandwehr
Re: 1JZ idle speed problem Fri, 22 October 2004 06:23 Go to previous messageGo to next message
Hi, had the same problem! Clean your Idle Speed Control Valve. Pop it off, and give it a good clean with throttle boby/carby cleaner. The Subaru cleaner is the GO, it foams up and gets into every crevice!
regards Chuck.
Milhouse
Re: 1JZ idle speed problem Fri, 22 October 2004 08:57 Go to previous messageGo to next message
Thanks Chuck! Will give it a whirl this weekend.
mx83toy I will let you know if it needs replacing. Thanks for your offer. Did you end up selling your car?
Simon
tortfeaser
Canberra, ACT
Re: 1JZ idle speed problem Fri, 16 September 2005 02:30 Go to previous messageGo to next message
I'm thinking about installing a Megasquirt ECU on a 1JZ.
Has the idle valve you guys are talking about got 3 pins or 4? IE is it a PWM valve or a stepper motor one?
Skip
Re: 1JZ idle speed problem Fri, 16 September 2005 04:36 Go to previous messageGo to next message
It will have 4 pins.
sideshow
Re: 1JZ idle speed problem Fri, 16 September 2005 06:25 Go to previous messageGo to next message
another thing to do after cleanin it is
take neg batt terminal off to reset ecu for a minute or so
then refit terminal
then run engine at 1500 rpm for 4 or 5 minutes
this will actually make the idle motor screw all way out and then all way in and find its limits
hopeuflly this will then help abit
Re: 1JZ idle speed problem Fri, 16 September 2005 06:29 Go to previous messageGo to next message
sideshow wrote on Fri, 16 September 2005 14:25
This is with your foot holding it at that rpm?
sideshow
Re: 1JZ idle speed problem Fri, 16 September 2005 06:48 Go to previous messageGo to next message
nar i usually just put a very thin cable tie or something similar under the throttle stop to hold throttle slightly open
Re: 1JZ idle speed problem Fri, 16 September 2005 06:49 Go to previous messageGo to next message
Cool
Will try.
sideshow
Re: 1JZ idle speed problem Fri, 16 September 2005 07:17 Go to previous messageGo to next message
this is only for std toyota ecus dont know if it works on any other crap hehe
Re: 1JZ idle speed problem Fri, 16 September 2005 07:22 Go to previous message
Yeah, stock ecu.
Previous Topic:ke20 ke10 leaf springs
Next Topic:MA70 -> JZA70 Conversion
Current Time: Mon Oct 26 08:42:36 UTC 2026
Total time taken to generate the page: 0.0075039863586426 seconds
