Toymods » Tech & Conversions » how long does the 1g-gte take to warm up - tranny problems
indian
south east - melbourne
how long does the 1g-gte take to warm up - tranny problems Thu, 21 October 2004 23:02 Go to next message
guys how lond does the 1g-gte motor take to warm up reason im asking is mine takes about 5 min atleast for the temp bar to move from cold to one and then never goes any further unless i start drivng the car even then a good 10-15 minutes drive and only then it will hit the half way mark (operating temp)
reason im asking is cause my transmission is doing this funny thing where it wont change int 4th gear when cold car will rev past 2500 rpm at 60k speed and only change at 71 km/hr then the rpm drps down to 1500 or so , then again when the car slows down again the gear jumps down and the rpm jumps up to 2500 its really annoying
anyone know what the problem
RA28
Re: how long does the 1g-gte take to warm up - tranny problems Thu, 21 October 2004 23:46 Go to previous messageGo to next message
A lot of auto trannies won't change into top gear until it's warm. My VL won't, and a frined with a SV21 says the destruction book says to drive <80 till it warms up to avoid over revving.
might just be life...(change to a manual Wink)
soaringmik
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 00:14 Go to previous messageGo to next message
Try turning the overdrive off and see what happens. I had a similar problem for a little while, but it seemed to sort itself out.. Confused
Have you tried replacing your thermostat?, sounds like it's stuck open,...
indian
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 00:40 Go to previous messageGo to next message
yeah ims suspecting the thermostat as well, maybe it stuck open maybe fault temp sensor an ideas boys ive also got the green colour coolant if thats makes any difference i know toyota needs the pink one i havent got arond that yet
overdrive button on all the time
turning it off makes no difference when the car is cold
soaringmik
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 01:57 Go to previous messageGo to next message
Leave the button off, and take it for a drive when cold,..
What your discribing sounds like your overdrive,..
indian
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 02:04 Go to previous messageGo to next message
yeah same problem wete the overdrive is n or off makes no difference in the car when its cold , only difference is
with overdrive on the car shifts in to 4th after 71km/hr (1600-700 rpm or so) and when the speed drops below 61km/hr the gears go back to 3rd and the rpm to 2500
with overdrive off the gear doesnt change at all even after going past 71km/hr havent driven it further than 80km/hr with overdrive off in the cold to check weter the gears are changing
when the car is warm it all shifts very nicely with overdrive on the car is doing 1500 rpm for a 60km/hr speed
[Updated on: Fri, 22 October 2004 02:05]
soaringmik
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 02:13 Go to previous messageGo to next message
Who knows,.. Sounds strange,..
Change the Thermostat, let the car warm up for 10mins before you drive, and you shouldn't have any problems.. Smile
indian
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 02:19 Go to previous messageGo to next message
yeah warming up for 10 minutes still dont do nothing to it , ca still does the same thing untill it gets t the halfway mark then everythings normal and shifts nicely , lolllllllll
its worse in winter , although now it doesnt take as much driving fr it to get warmed up and then it shifts like nothing ever happened
MR 1JZ
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 02:40 Go to previous messageGo to next message
I had the same problem with my original motor dude, it doesnt change into fourth gear unless you hit over 70kph, i just changed the thermostat so it actually gets to operating temperature, all good now Very Happy
changing the thermostat takes about 10 minutes i would do it if I were you, assuming its the original thermo that came with the car its probably 16 years old and seized like a mofo Very Happy
indian
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 02:42 Go to previous messageGo to next message
LOLLLLLLLL, CHEERS MATE IIL DO THAT ASAP AND LET YAAL KNOW WHAT HAPPENED
MR 1JZ
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 02:50 Go to previous messageGo to next message
button next to the "a" key, you should try it sometime Rolling Eyes
Laughing
indian
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 04:54 Go to previous messageGo to next message
lolll, guys
now i cant change the thermostat if i dont know the part number for it now can i
anyone here know the part number for the 1g-gte thermostat
thanks a million , to all who have helped
MR 1JZ
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 05:03 Go to previous messageGo to next message
go to toyota they will get one for you Very Happy
Bugman
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 05:10 Go to previous messageGo to next message
get an 82deg one for a 4age.
or better yet pull it out and take it to your local parts shop.
dont forget the rubber seal for it too
MR 1JZ
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 05:21 Go to previous messageGo to next message
dont take the seal anywhere if its in good condition, they are hard to find in the right size, if its good leave it somewhere safe so you dont lose it.
The seals are a good idea tho as they mean the thermo housing doesnt need a gasket unlike some other cars
indian
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 06:06 Go to previous messageGo to next message
lat time i asked toyota didnt wanna know anything for an imported car pricks like them
anyone else know anything , weter another car like camry or crown , cressy share the same thermostat
mr 1g-gte how much did your thermostat cost
also people where exactly is it located i havent looked yet
[Updated on: Fri, 22 October 2004 06:08]
MR 1JZ
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 06:29 Go to previous messageGo to next message
thermostat was $12, and it is located where the top radiator hose goes into the engine, two bolts pretty simple stuff really Very Happy
indian
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 06:31 Go to previous messageGo to next message
cool so u got them from toyota , thanks mate iil goget the damn thing and see what happens after i do it
hiopefully my tranny will work well and i wont have to wait for 10 min to warm up 1 bar
lollll
MR 1JZ
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 06:35 Go to previous messageGo to next message
correct me if I am wrong here but I think that the thermostat will be the same as a Lesux IS200 one?
Anyone want to shed some more light here people?
Bugman
Re: how long does the 1g-gte take to warm up - tranny problems Fri, 22 October 2004 08:04 Go to previous messageGo to next message
why wont you listen to me
go to any parts shop and buy a 4a-ge one off a twin cam corrolla..
they are in abundance everywhere.
you can also select your temp too...
either 82 or 88 deg is what you require.
indian
Re: how long does the 1g-gte take to warm up - tranny problems Sun, 24 October 2004 22:52 Go to previous messageGo to next message
ok bugman must have mised u previuos post
i will tr ur option if the toyota freaks dont have the part
Bugman
Re: how long does the 1g-gte take to warm up - tranny problems Sun, 24 October 2004 23:07 Go to previous messageGo to next message
just go to your local parts shop.
indian
Re: how long does the 1g-gte take to warm up - tranny problems Mon, 25 October 2004 00:11 Go to previous messageGo to next message
dude are u sure these things will fit im just a bit curious and what temp setting should i get out of the two mentioned i like th car to warm up faster
[Updated on: Mon, 25 October 2004 00:11]
MR 1JZ
Re: how long does the 1g-gte take to warm up - tranny problems Mon, 25 October 2004 00:16 Go to previous messageGo to next message
get the 82 Degree one, summer is coming up and you would rather that it kicked in at a cooler temp, trust me on that Smile
Mine is an 82 Degree one, I think, and it warms up fine and runs excellently, for instance it was about 26-28 degrees yesterday and I went for a cruise down to the bay and was stuck in traffic for a decent hour and TEMP didnt even jump one bar, which is handy Smile
indian
Re: how long does the 1g-gte take to warm up - tranny problems Mon, 25 October 2004 00:28 Go to previous messageGo to next message
mr 1g-gte thanks for that iil get the 82 then did u put the 4a-ge twin cam corolla one in as well or did u get the one for the 1g-gte i dont wanna ruin my car thats all as its running perfectly bar the overdrive due to the thermo being open all the time
would it be better to change coolant as well as i have the green one in it also drain plug for radiatir is it located like normal cars unddeer the radiator , cant see shit from under the car as its got all that plastic covering and all
MR 1JZ
Re: how long does the 1g-gte take to warm up - tranny problems Mon, 25 October 2004 00:34 Go to previous messageGo to next message
You might as well change coolant, ive got to do mine very soon, so let me know what you use and how it goes for you, to be honest im just thinking of getting some of that toyota coolant, even tho a little pricey it must be fairly decent if they use it in all thier services. Smile
indian
Re: how long does the 1g-gte take to warm up - tranny problems Mon, 25 October 2004 00:37 Go to previous messageGo to next message
yeah im def getting the pink/red coloured stuff to go in the car its got some special thing in it thats good for the toyota motors secifically
im just gonna flush out thwe green stuff fully as if u mix them they are not good cause they react with each other and is bad for the engine so make sure u get all the green one out even from the heater core
Bugman
Re: how long does the 1g-gte take to warm up - tranny problems Mon, 25 October 2004 02:04 Go to previous messageGo to next message
it's just the physical size you need to know.
and it's the same as the 4age one..
I put one in my car afew weeks ago.
indian
Re: how long does the 1g-gte take to warm up - tranny problems Mon, 25 October 2004 02:32 Go to previous message
sorry 4got to ask one more thing
what year 4a-ge model was it from ????
Previous Topic:F series info
Next Topic:DIY Air Intake Mods for GZE motor
Current Time: Tue Oct 20 13:05:30 UTC 2026
Total time taken to generate the page: 0.055101871490479 seconds
