Classifieds » Car/Engine Electronics & Audio » FS: ALPINE MRP-F240 4/3/2 CHANNEL AMP *BRAND NEW*
etone
FS: ALPINE MRP-F240 4/3/2 CHANNEL AMP *BRAND NEW* Fri, 22 October 2004 00:44
BRAND NEW in BOX
Description:
The MRP-F240 is designed to work in a variety of applications: With 40 watts RMS per channel in 4-channel mode, you can easily drive two pairs of full-range or component speakers. Or, bridge the amp to 2-channel mode for 100 watts RMS x 2. That power makes your music sound tighter and more detailed at all volume levels.
40 watts RMS x 4 at 4 ohms
50 watts RMS x 4 at 2 ohms
100 watts RMS x 2 bridged output at 4 ohms
2-, 3-, or 4-channel output
4-ohm stable in bridged mode
Tri-Way capable
requires 10-gauge power and ground leads wiring and hardware not included with amplifier
selectable high-pass/low-pass crossover at 80 Hz, 18 dB/octave (2 separate crossovers, one for channels 1 & 2, another for channels 3 & 4)
subsonic filter at 15 Hz for channels 3 & 4
tuned Bass EQ (0-12 dB bass boost at 50 Hz) for channels 3 & 4
preamp outputs
MOSFET power supply
STAR Topology (minimizes internal noise and prevents ground interference)
speaker- and preamp-level inputs
gold-plated screw terminals
10-1/2"W x 2-7/16"H x 9-9/16"D
More [+]
Selling as No longer required.
Item is located in Sydney available for Pick-up or COD
Selling for $275. ONO
e-mail: http10@aol.com
Previous Topic:IMMOBILISER SYSTEM
Next Topic:custom box, 15in subs and possible amps to suit ra28
Current Time: Sat Oct 24 22:59:09 UTC 2026
Total time taken to generate the page: 0.0060739517211914 seconds
