Toymods » Tech & Conversions » sprinter brake adjustment
purpleminiep
Mentone
sprinter brake adjustment Wed, 02 October 2002 08:57 Go to next message
How do i adjust the rear brake drums on my sprinter. I have a fairly long pedal after changing the wheel cyclinders. I have bled all the air out. How do the self adjusters work. Do they stuff up or get stuck
Brad
Hunty
Re: sprinter brake adjustment Wed, 02 October 2002 17:30 Go to previous message
push in the button on the handbrake and pump it up and down about 1000 times!! if you listen carefully you can hear a click everytime u pull tha handbrake up keep doin it till the clicks go away then tighten up the handbrake cable if its loose and if the pedal play is still long re bleed the system. Thats what i did in my AE82 im sure the process is similar.
Previous Topic:out with the T2 in with the ?
Next Topic:7m-ge model spec differences
Current Time: Thu Oct 29 21:04:52 UTC 2026
Total time taken to generate the page: 0.033033847808838 seconds
