Toymods » Tech & Conversions » gear drive on K-engine camshaft !!!
5KinKP60
Finland
gear drive on K-engine camshaft !!! Wed, 02 October 2002 09:24 Go to next message
Would anyone had believed this ?
http://homepage2.nifty.com/hiro-cy/kp30kai/0025.jpg
Grega
melbourne.victoria.austra...
Re: gear drive on K-engine camshaft !!! Wed, 02 October 2002 21:55 Go to previous messageGo to next message
why?
(i know, i know - coz you CAN)
Bill Sherwood
Brisbane / Gold Coast
Re: gear drive on K-engine camshaft !!! Thu, 03 October 2002 02:17 Go to previous messageGo to next message
I can only echo - Why?
We never had any problems with the ~8700rpm 3K we used to use in the racer, with a stock chain drive. The valve gear was always the limiting factor.
Bill Sherwood
Re: gear drive on K-engine camshaft !!! Thu, 03 October 2002 13:53 Go to previous messageGo to next message
Also, have you got a reverse-direction cam in there? It won't start otherwise.
Re: gear drive on K-engine camshaft !!! Thu, 03 October 2002 14:02 Go to previous messageGo to next message
Wish mine had one of those, then it might sound SLIGHTLY less like a diesel... especially on startup... hang on, maybe I could shout it an oil change one day.... hmmmm, naaaaahhhh... ($7 worth of Home Brand oil is borderline high maitenance cost for that car!)
Grega
Re: gear drive on K-engine camshaft !!! Thu, 03 October 2002 21:19 Go to previous messageGo to next message
hey bill you sure on the reverse direction cam bit? if the crank pulley drives clockwise, it would drive that intermediate gear anti clockwise, which in turn would drive the cam gear clockwise.
or have i taken too many stupid pills this morning?
Bill Sherwood
Re: gear drive on K-engine camshaft !!! Fri, 04 October 2002 04:41 Go to previous messageGo to next message
Yep, I got it arse about.
Disregard the other post.
bmak
Re: gear drive on K-engine camshaft !!! Fri, 04 October 2002 11:33 Go to previous messageGo to next message
also looks like the mount have been modified so it sits straight up & it has a spacer for the carbies
Purple_Beasty
New Zealand
icon14.gif  Re: gear drive on K-engine camshaft !!! Sat, 05 October 2002 10:26 Go to previous messageGo to next message
TRD used to sell upright kits for the race k series motor which removed the lean from the motor and required a new bellhousing as well (I think). Not sure of the advantages of this setup but there had to be a reason.
Bill Sherwood
Re: gear drive on K-engine camshaft !!! Sat, 05 October 2002 14:28 Go to previous messageGo to next message
From memory, it's to help the oil return from the head. I think that the drains are on the camshaft side, and so leaning the engine that way helps the oil fall back into the sump.
5KinKP60
Finland
Re: gear drive on K-engine camshaft !!! Sat, 05 October 2002 17:41 Go to previous message
Bill remembers right, drains are on the camshaft side.
I've heard a different reason for tilting K-series engines in smaller Toyotas for racing. There will be no enough clearance to bolt on sidedraught twin carbs. I managed to run into one pic of such enginebay - it was evident that those carbies really needed that inch or two to fit there. Engine was upright and there seemed to be like 1,5cm clearance from velocity trumpet to inner fender.
-A.
Previous Topic:How to crack open 18R alternator??
Next Topic:EP91 Starlet Wiring Diagrams
Current Time: Mon Oct 26 18:31:39 UTC 2026
Total time taken to generate the page: 0.0079240798950195 seconds
