Toymods » Tech & Conversions » 4age troubleshooting
Satoshi
4age troubleshooting Fri, 22 October 2004 05:36 Go to next message
i just changed my engine oil and oil filter yesterday..took a rag and thorougly wipe the spark plugs (havent change them yet)..
ok..after driving it this morning..my engine feels abit lagging during the acceleration (can feel that the engine hesistated a little bit through the pedal)...pass 4000rpm in 1st and 2nd gear..maybe 3rd too but unsure
what i realised frm the behaviour of the engine after yesterday's servicing (I DONT THINK I DID A DODGY JOB!)..the lagging part also comes inbetween changing from 1st gear to 2nd gear...there was about 0.5seconds lag after engaging into 2nd gear...the lag comes in when i rev 1st gear up to 5000rpm-7000rpm...
before i service the car...there wasnt this problem...
Help me to troubleshoot...
feral4mr2
Bundaberg, Qld.
Re: 4age troubleshooting Fri, 22 October 2004 10:57 Go to previous messageGo to next message
what level of oil do you have in the sump?
and why did you need to wipe the spark plugs.
ae95
Re: 4age troubleshooting Fri, 22 October 2004 11:01 Go to previous messageGo to next message
id replace the plugs and check the oil level
Satoshi
Re: 4age troubleshooting Fri, 22 October 2004 13:07 Go to previous messageGo to next message
my oil level (according to dipstick) is little bit above the FULL line...got to check again..
hmm..maybe i should change the plugs and see how it goes..
btw...what happens if there's too much of engine oil?
levin_boi
melb
Re: 4age troubleshooting Fri, 22 October 2004 14:16 Go to previous messageGo to next message
your engine bogs down and becomes laggy and sluggish when you over fill the oil. just keep running it and it should return to normal as teh oil burns away. or if you are impatient u can jus drain a lil bit of oil from teh sump. hope dis helps
sab
Satoshi
Re: 4age troubleshooting Fri, 22 October 2004 16:30 Go to previous messageGo to next message
i've overfilled it by probably 1 or 2mm more..but didnt know it might cause these problems..i'll change the plugs and drain a lil oil...and see what happens..
allencr
tallahassee FL usOFa
Re: 4age troubleshooting Fri, 22 October 2004 16:46 Go to previous messageGo to next message
is it missing or running rough when accelerating?
spark plug/s.
i don't have a clue what "engine hesistated a little bit through the pedal" means, and "thorougly wipe the spark plugs" is even beyond guessing.
feral4mr2
Bundaberg, Qld.
Re: 4age troubleshooting Fri, 22 October 2004 22:05 Go to previous messageGo to next message
Satoshi wrote on Sat, 23 October 2004 02:30
1-2mm over the full mark wont/shouldnt bother it at all.
did you actualy pull the spark plugs out? if so are the plug leads in the right configuration and on the plugs proper (eg. one lead half hanging off).
Satoshi
Re: 4age troubleshooting Sat, 23 October 2004 00:36 Go to previous message
did not pull the plugs out..just took of the leeds and clean the plug's tip...
Previous Topic:Is there a difference between 4age and 4ac thermostat in AE82?
Next Topic:2 Questions
Current Time: Wed Nov 18 20:11:24 UTC 2026
Total time taken to generate the page: 0.0067379474639893 seconds
