Toymods » Tech & Conversions » Cold Start Injectors, are they of any use?
86tt
Cold Start Injectors, are they of any use? Fri, 22 October 2004 15:25 Go to next message
If you've got an aftermarket computer, with water temp adj, is there any reason to connect the cold start injector?
(that's what this thing is called right?)
http://members.dodo.com.au/~l88/coldstart.jpg
gearb0x
Re: Cold Start Injectors, are they of any use? Fri, 22 October 2004 15:27 Go to previous messageGo to next message
they are pretty good for cold starts
if you have aftermarket efi with some sort of cold start fuel enrichment u can remove it but if keeping the stock computer u should prolly keep it Smile
[Updated on: Fri, 22 October 2004 15:28]
STR8 2.8
Re: Cold Start Injectors, are they of any use? Sat, 23 October 2004 03:57 Go to previous messageGo to next message
bah who needs it!
car will just take longer to start.
i dont run one, and i have never had trouble starting the car
86tt
Re: Cold Start Injectors, are they of any use? Sat, 23 October 2004 04:12 Go to previous messageGo to next message
so with Microtech MTX8 I can scrap the injector right?
Re: Cold Start Injectors, are they of any use? Sat, 23 October 2004 10:25 Go to previous messageGo to next message
Yeah get rid of it. Unless you live in Siberia it's not really necessary, even with the factory ECU!
86tt
Re: Cold Start Injectors, are they of any use? Sat, 23 October 2004 13:06 Go to previous messageGo to next message
then can I actually take the cold start injector off and install some air bypass valve for air cond / cold start?
Grant
Newcastle, NSW, Australia
Re: Cold Start Injectors, are they of any use? Sat, 23 October 2004 23:52 Go to previous messageGo to next message
That depends on what sort of aftermarket ecu your using and how well it's set up for cold start. If the tuner has experience with that engine or your prepared to spend the extra money for him to play with the cold start every morning, than it can usually be set up very well without the need of a cold start valve.
STR8 2.8
Re: Cold Start Injectors, are they of any use? Sun, 24 October 2004 00:07 Go to previous messageGo to next message
just unplug it and leave it there
Re: Cold Start Injectors, are they of any use? Sun, 24 October 2004 00:55 Go to previous messageGo to next message
cold start injector (read: valve) is really only useful BELOW -10degC.
I dont run one with a stock 4age. mines fine.
86tt
Re: Cold Start Injectors, are they of any use? Sun, 24 October 2004 02:21 Go to previous message
me car's always stall below water temp of 50c degrees and I'm trying to find a solution.. Razz
Previous Topic:1jz single turbo selection
Next Topic:AE86 Struts into a ta23
Current Time: Thu Nov 19 08:08:17 UTC 2026
Total time taken to generate the page: 0.010773897171021 seconds
