Toymods » Tech & Conversions » Help 3tgte problems
rke_011
adelaide
Help 3tgte problems Sat, 23 October 2004 09:38 Go to next message
Hey people i just got mt import gtt corona all on the road and legal. Was running ok but seemed exhaust was too restrictive so i invested in a 3in. Now im having trouble with the car cutting off when it starts boosting and going around 4500 - 5000 rpm. i was told a boost cut controller mite fix this so i got one. But cant seem to find the diagrams that tell me where to connect it too. Has anyone done this? or anyone know of the diagram thingo im talking about and where i can find it?
all help apprectiated please private msg me if you can help because i always seem too lose my posts.
Mat
Re: Help 3tgte problems Sat, 23 October 2004 09:48 Go to previous messageGo to next message
Ahh no man! You don't need to purchase a boost cut controller.
The factory 3tgte EFI system runs a few pressure switches (3 from memory) around on the drivers side near the brake booster/shock tower area.
One of these you can disconnect and bingo! no more boost cut! Totally free of cost also Smile
Its PC pinout on the ecu, I think this is a black/white wire. Hopefully the same colour at the pressure switch. Anyhow.. try disconnecting it and should fix your problem.
The other 2 pressure switches, one is for fuel enrichment and the other for the knock sensor from memory. So if you get it wrong just try another one.
Joel
rke_011
adelaide
Re: Help 3tgte problems Sat, 23 October 2004 10:03 Go to previous messageGo to next message
thanks heaps man. pitty i got one already Razz only paid 80 bux for a Greddy one so i dont care Smile im gonna go try it now Smile
wish me luck Smile
thanks again
Re: Help 3tgte problems Sat, 23 October 2004 10:06 Go to previous messageGo to next message
Haha so we'll see a boost cut defender for sale shortly eh?
You'll be fine with it, only trick is finding the right pressure switch. But you can just use process of elimination really..
The fuel enrichment one you don't want to leave disconnected for too long but just for a quick test it shouldn't do any damage.
rke_011
adelaide
Re: Help 3tgte problems Sat, 23 October 2004 10:18 Go to previous messageGo to next message
just another quick qs. i have looked at it.. so all i gotta do is disconnect the wire going to it? is this safe to do or will it over boost? im excited think ill be croozin soon!
Re: Help 3tgte problems Sat, 23 October 2004 10:32 Go to previous messageGo to next message
Yeah you can disconnect the wire or the vac line going into it. All the wires have a plug on them.. I cant remember what method I did with mine.
It wont overboost assuming the wastegate is doing its job. The pressure switch is there to cut fuel after 6.5psi or so. Which is approx what the wastegate is set to. But like you've found when you get a new exhaust etc the boost will get a bit higher and the fuel cut comes into play.
Its damn annoying and bad for the engine as it cuts fuel so engine runs really lean. So you are better off disconnecting it.
Joel
rke_011
adelaide
Re: Help 3tgte problems Sat, 23 October 2004 11:51 Go to previous messageGo to next message
worked for a little while.. but not long enough Sad
CLG
Perth, Western Australia
Re: Help 3tgte problems Sat, 23 October 2004 12:42 Go to previous messageGo to next message
No, leave the wire connected to the sensor, but remove the vacuum line to the sensor - it will fool the sensor into thinking it is not boosting, by simply reading atmosphere all the time. the other pressure sensor will deliver more fuel while boosting as it still senses boost through another vacuum line.
Re: Help 3tgte problems Sun, 24 October 2004 00:12 Go to previous messageGo to next message
Cool thanks for clarifying that.. Couldn't remember if I disconnected the wire or the vac line..
Joel
rke_011
adelaide
Re: Help 3tgte problems Sun, 24 October 2004 08:42 Go to previous message
Hey still having problems with cutting off.. can anyone tell me exactly which one needs too be disconnected?
i have been disconnecting the one with a t-piece and blocking the other side off.
any pictures of what one needs to be disconnected.
i hope im disconecting the rite thing Smile
i cant keep letting commodores beat me Sad
[Updated on: Sun, 24 October 2004 08:46]
Previous Topic:Buying new Thermo Fans
Next Topic:differential for an ra25... last owner made a mismatch
Current Time: Thu Nov 19 10:30:45 UTC 2026
Total time taken to generate the page: 0.013159036636353 seconds
