Toymods » Tech & Conversions » 2tg sump modification
The Untouchable
Ballarat
2tg sump modification Sat, 23 October 2004 10:02 Go to next message
hey ive heard that the 2tg dry sump setup isnt ideal...and that it will benefit from a baffled setup.
um, can someone explain the difference between the systems? and the pros/cons if possible
Re: 2tg sump modification Sat, 23 October 2004 10:41 Go to previous messageGo to next message
I'd try talking to YelloRolla about this one, he has setup quite a few sumps and knows his stuff.
Joel
Re: 2tg sump modification Sat, 23 October 2004 10:45 Go to previous messageGo to next message
2T-G's have a wet sump, as do pretty much all production cars. The only dry sump production engine I can think of is the old 6.9L Merc V8 from the 70's.
Anyway, most old Toyota engines suffer from oil surge and the 2T-G is no exception. Pretty much any form of baffling will be an improvement, but yeah talk to YelloRolla for specifics.
[Updated on: Sat, 23 October 2004 10:46]
Re: 2tg sump modification Sat, 23 October 2004 10:50 Go to previous messageGo to next message
Hmm I misread that first post regards the dry sump. typo I assume? Or are you asking pro/con of dry vs wet?
[Updated on: Sat, 23 October 2004 10:51]
The Untouchable
Ballarat
Re: 2tg sump modification Sat, 23 October 2004 10:55 Go to previous messageGo to next message
yeah, i dont know anything about the two at all. i think i got dry sump for a 2tg coz i looked at the specs for the rallt version of the ta22.
just a quick q, obviously i will need a proper rundown, but what sort of thing would u do as a baffling procedure?
juzzo84
Hornsby, N.S.W
Re: 2tg sump modification Sat, 23 October 2004 11:01 Go to previous messageGo to next message
you would weld small walls into the sump to help reduce oil splash and sway!
The Untouchable
Ballarat
Re: 2tg sump modification Sat, 23 October 2004 11:10 Go to previous messageGo to next message
hey juzzo sign into msn if you can, gotta have a quick chat to you about the cam specs (again)
cwhelan
Adelaide, Semaphore
Re: 2tg sump modification Wed, 24 November 2004 22:27 Go to previous message
Hiya Untouchable....
Did you find out the info on baffled sump verses dry sump?
I have done baffles in most engines that I rebuild for club events, It is very easy if you have a bit of time. Done properly, you will have very little problem on oil starvation on hard cornering. Don't just cut steel and just weld in wherever. While the engine is completely stripped cut min. 1.5mm sleel zintex to the shape of your cardboard templates of the sump. Make sure you have your crank and oil pump/pickup still in the block, so as to fit the templates in such possition as to miss the moving parts and pickup. Make sure you cut the zintex 5mm bigger than your template so you can cut tabs into the profile and bend at 90 deg. Once you mark out where the templates fit best, get a small dremel or di-grinder to clean up the area you will be brazing to. I find that brazing works best in this small job as it has a little bit of flex in the weld. The secret here is to make sure that for every inch of steel you have on the baffle plate there is an 8-10mm hole drilled and deburred. The importance of these holes is that you will still have constant flow. The trick is to make sure the holes start at the base of the plates so that you will have flow at the bottom of the sump. Carefully line up your plates into the sump with the marks you have made from the templates and tack into place on each corner. Once all plates are in place, place the sump onto the block and recheck for any interferance. At this stage, all should be ok. Its now time to stitch braze into place and then finaly clean up any small bits of suspect braze. The last thing you want is to have a bit of weld come loose in your block.
Previous Topic:Disappointing Supra Dyno
Next Topic:TA23 wiring diagram
Current Time: Fri Nov 20 18:26:08 UTC 2026
Total time taken to generate the page: 0.023011922836304 seconds
