Toymods » Tech & Conversions » WTF my 2t-geu sounds like a wrx???
w810sc
sydney - paramatta
WTF my 2t-geu sounds like a wrx??? Sat, 23 October 2004 12:19 Go to next message
i have a 75 celica with a stock 2t-geu with twin 40mm solex carbies and ramflow air filters on it, 4-2-1 extractors and an electronic fuel pump.
i couldnt find any thing on search hat was related.
long story short it sounds like a wrx with an exhaust and lacks acceleration.
i have checked the carbies, air filter and the spark plugs and found nothing wronng. I also cheaked the distributer timing and found that if i rotate it clockwise a bit it goes back close to normal but idels higher.
what else should i check to ensure it wont happen again?
this is the second time it has happened, the first was when i missed 2nd gear and redlined 1st, which led to one of my carbies sucking the air filter into one of the air intakes (1st cylinder). this has resulted in that mysterious wrx noise.
much help needed due to people looking for a wrx and seeing me when driving up the road. they're like "WTF!! thats not a wrx"
tanman
Re: WTF my 2t-geu sounds like a wrx??? Sat, 23 October 2004 22:12 Go to previous messageGo to next message
broken ring land will do that.
w810sc
sydney - paramatta
Re: WTF my 2t-geu sounds like a wrx??? Sun, 24 October 2004 05:07 Go to previous messageGo to next message
thanks mate, just what i need a busted ring. is there any thing else it could be?
tanman
Re: WTF my 2t-geu sounds like a wrx??? Sun, 24 October 2004 05:31 Go to previous messageGo to next message
exhaust manifold leak?
JZX-83T
Re: WTF my 2t-geu sounds like a wrx??? Sun, 24 October 2004 05:33 Go to previous messageGo to next message
Check the oil, i had the same problem with my 4ag ae82 once. Sounds like a wrx at low revs and no power, once the revs got up it seemed fine. couldn't work it out untill i checked the oil there was none! Embarassed mental note if you put thin oil in a hi km motor check the oil regularly! turned out i cracked the head between a water jacket and water was getting into the cylinder. Good old chemi-weld helped the tuff 4a live a bit longer
Danish
Re: WTF my 2t-geu sounds like a wrx??? Sun, 24 October 2004 07:33 Go to previous messageGo to next message
My car sounds like a WRX with no power when it's running on 5 cylinders or less.
SilverGhost
Re: WTF my 2t-geu sounds like a wrx??? Sun, 24 October 2004 11:40 Go to previous messageGo to next message
I concur with Danish, if your engine misses one one or more cylinders it can give that 'rexy' exhaust note and lack of power, you should also notice it idles rougher and/or at a lower speed
ta2272
Re: WTF my 2t-geu sounds like a wrx??? Sun, 24 October 2004 12:22 Go to previous messageGo to next message
Ive been told my carsounded like a wrx many times nothing wrong with it just the noice the carbs and exhaust make in sync
DuMp
Rockingham,WA
icon10.gif  Re: WTF my 2t-geu sounds like a wrx??? Sun, 24 October 2004 13:40 Go to previous messageGo to next message
Quote:
Re: WTF my 2t-geu sounds like a wrx??? Sun, 24 October 2004 15:33
yes thats would be right ... considering its a 4 cylinder engine Rolling Eyes
boris
On probation
Brisbane, Queensland
Re: WTF my 2t-geu sounds like a wrx??? Mon, 25 October 2004 01:49 Go to previous messageGo to next message
DuMp i think danish was talking about his car running on 5 cylinders or less not the 2tgeu...
indian
south east - melbourne
Re: WTF my 2t-geu sounds like a wrx??? Mon, 25 October 2004 02:24 Go to previous messageGo to next message
head gasket will do it as well sometimes
mostly does that when one cylinder isnt running and the idle will be shit and yeah lots of power loss
w810sc
sydney - paramatta
Re: WTF my 2t-geu sounds like a wrx??? Mon, 25 October 2004 06:25 Go to previous messageGo to next message
thanks for yor help fellas, you were right to say when one cylinder goes it makes that noice (when my carby sucked the airfilter in one intake), but i get the problem every time i start the car, and after a while of reving the engine it goes away. i have cheaked the oil its still a bit yellow, the engine has only done around 97,000km and today i went out and bought carby cleaner the one where you mix it with petrol. i also cheaked the spark plugs again making sure they're not getting to hot and re-tuned the carby. lastly i turned the distributer anti-clockwise just a bit and had it ideling at 900-1000rpm. my main concern is why does it start and then go away?
should i do the following:
- compression test
- get carbies properly tuned
- do a full service
- what else would any of you fellas suggest.
once again thanks for your suggestions.
[Updated on: Mon, 25 October 2004 06:27]
Re: WTF my 2t-geu sounds like a wrx??? Mon, 25 October 2004 06:45 Go to previous messageGo to next message
when you start it up, and it's sounding liek a WRX, take off the plug leads one at a time and find out which cylinder is not firing..
i would suggest buying or borrowing a differetn set of plug leads also, in case one of yours is busted.
Bill Sherwood
Brisbane / Gold Coast
Re: WTF my 2t-geu sounds like a wrx??? Mon, 25 October 2004 06:53 Go to previous messageGo to next message
There's a slight chance it's the auxiliary venturi in the Solex carbys. In two out of two that I've fiddled with, the aux venturi's have either been loose or have completely falled out. Unfortunately the carbies are shit and the only way to fix them is to fit Webers or better still EFI.
w810sc
sydney - paramatta
Re: WTF my 2t-geu sounds like a wrx??? Tue, 26 October 2004 09:02 Go to previous messageGo to next message
i have checked the leads and they are fine when it's running normal, ill cheak them again prior to warming up engine(when wrx noise).
Bill Sherwood can you please explain to me what is the purpose of an auxiliary venturi?
where on the carby would i find these auxiliary venturi?
what would be the cause of this failing or falling off? eg loose screw(if any), blocked etc.
how or/and can this be modified? => what would be a band-aid fix to get the car running for a couple of months.(hopely 4 months, this will give me enough time to get the rest of the money for an engin conversion)
suggestions appreciated thanks for the feed back fellas.
Bill Sherwood
Re: WTF my 2t-geu sounds like a wrx??? Tue, 26 October 2004 10:33 Go to previous messageGo to next message
The auxiliary venturi is the gadget that looks like a little tube , and it sits in the centre of the carby throat. It's a small venturi in itself, and it's the gadget that lets the fuel get sucked into the airstream, then into the engine.
If that falls out, then the fuel will still get sucked in, but in large drops instead of much finer droplets, and at some weird mixture ratio so the engine runs like a dog.
The ones I had fall out did it all by themselves and I'm not sure why. They were untouched, as they came from the factory.
There's a small screw under the middle of the carby body on each side that screws up into the bottom of the auxiliary venturi to hold it in place. Once that screw gets a little loose, it works around and burrs over the bottom of the venturi and it eventually falls out. They can't be fixed.
Again, the only real way to fix it is to put on some decent carbies such as 40mm Webers.
They're junk.
w810sc
sydney - paramatta
Re: WTF my 2t-geu sounds like a wrx??? Wed, 27 October 2004 06:12 Go to previous message
damn that helped me alot. the strangest thing just happend this morning, i went to start my car and it started fine no more rexy noise. i went to check my distributer leads and all was fine. only problem is that every time i rev it from the carby linkage with the airfilters off, it spits out a tiny spray of petrol after i release the throttle. i dont think this is normal for any carby or is it?. can some one please tell me why this happens and how to fix it. by the way the tiny sprays are comming from the auxiliary venturi. after a while i gotta keep cleaning the airfilters cuse they get soaked in petrol.
any advice appreciated. thanks fellas
[Updated on: Wed, 27 October 2004 06:15]
Previous Topic:3TGTE INTO KE55
Next Topic:Fuel Question ?
Current Time: Fri Oct 30 14:18:00 UTC 2026
Total time taken to generate the page: 0.010941028594971 seconds
