Toymods » Tech & Conversions » st162 jumpy in low rpm acceleration
Matt-itude
Perth, Western Australia
st162 jumpy in low rpm acceleration Sun, 24 October 2004 01:50 Go to next message
i drive a 1988 celica sx (st162), and my car is sometimes jumpy like theres no combustion when im accelerating at low rpm (less than 2000)
also sometimes when im at idle, and i put my foot on the accelerator, the car stalls?
is this a problem of the car just not getting enough air, or an idle control issue, or the car not getting enough fuel?
Thanks for any help
// Matt
RWDboy
Re: st162 jumpy in low rpm acceleration Sun, 24 October 2004 03:42 Go to previous messageGo to next message
Cars not getting enough air is pretty rare Smile
what rpm does your car idle at?
Matt-itude
Re: st162 jumpy in low rpm acceleration Sun, 24 October 2004 04:09 Go to previous messageGo to next message
about 750-800
bergerac
Re: st162 jumpy in low rpm acceleration Sun, 24 October 2004 05:58 Go to previous messageGo to next message
Mine was doing this when i had a tear in the intake hose between the AFM and the plenum, the engine movement would open up the tear and bypass the AFM causing the engine to thing it was getting no air and stall!
Jorrs
Coffs Harbour
Re: st162 jumpy in low rpm acceleration Sun, 24 October 2004 07:34 Go to previous messageGo to next message
hey yeh i had this problem as well , it is my distributor cap and the main lead from the coil to the cap it is buggered and becomes loose and falls of nearly which causes the power loses,
let me know what it is
Aust162
Melb, Victoria
Re: st162 jumpy in low rpm acceleration Sun, 24 October 2004 08:15 Go to previous message
yep, intake pipe from afm to tb. its prolly cracked around the bended part. check its tight.i had the same problem. i just taped the crack up with gaffa Razz
Previous Topic:differential for an ra25... last owner made a mismatch
Next Topic:T series blocks...all the same Water Pump?
Current Time: Tue Nov 24 19:17:21 UTC 2026
Total time taken to generate the page: 0.022576093673706 seconds
