Toymods » Tech & Conversions » Problem with Idle on a 1990 Seca SX after fitting Unifilter
cjeff
icon5.gif  Problem with Idle on a 1990 Seca SX after fitting Unifilter Thu, 03 October 2002 01:48 Go to next message
I just fitted a unifilter Rampod last night. The original airbox has 2 sensors going into it. The air temp probe. The other one is supposedly something that keeps the idle up when the A/C is on (that's what Unifilter told me). They said that just to tie it up next to the filter, that it doesn't really matter. Well I did just that, but now once the engine is warm, the idle drops to about 500rpm and stalls. Has anyone had this problem? Can anyone help me?
Regards - Craig
cjeff
Re: Problem with Idle on a 1990 Seca SX after fitting Unifilter Thu, 03 October 2002 08:10 Go to previous messageGo to next message
The link to the photo's are as follows...
http://www.geocities.com/craig_jeffries/1.jpg
http://www.geocities.com/craig_jeffries/2.jpg
Note the bolt I have placed in the tube (the one next to the filter) going into the Throttle body - should i have done this?
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Problem with Idle on a 1990 Seca SX after fitting Unifilter Thu, 03 October 2002 12:55 Go to previous message
That tube you've shoved the bolt in, where did that used to go?
As for the other thing, I don't really see how it could be your problem. If it's part of the idle up valve for the air-con & power steering, it would only be fitted to the box so that the extra air it supplies the motor is filtered, so either connect it back up behind the airfilter or put a little filter of some sort over it (almost anything would be better than nothing).
Previous Topic:20V Extractors on 16V 4AGE
Next Topic:Gear cables - desperate
Current Time: Thu Oct 22 10:51:38 UTC 2026
Total time taken to generate the page: 0.0042629241943359 seconds
