Toymods » Tech & Conversions » Leaks in my ra28
chrishulbert
Castle Hill NSW
Leaks in my ra28 Mon, 25 October 2004 05:46 Go to next message
When it rains, it leaks into my ra28. I've resealed the windscreen (neatly, with some gutter sealant Laughing ) but it didn't fix it.
It seems to drip slowly just onto your right foot if you're on the drivers side, and drips like 10cm to the left of your left foot on the passenger side.
Any ideas where this is coming from?
Re: Leaks in my ra28 Mon, 25 October 2004 06:01 Go to previous messageGo to next message
Check your drivers side air vent, I vaguely recall having dramas with that leaking in my RA23 a while back!
munki
Gold Coast
Re: Leaks in my ra28 Mon, 25 October 2004 06:13 Go to previous messageGo to next message
check the drivers side grommet where the loom pokes through behind the guard, or the accellerator linkage grommet. Otherwise there could be a problem with the rubber and windscreen.
chrishulbert
Castle Hill NSW
Re: Leaks in my ra28 Mon, 25 October 2004 06:49 Go to previous messageGo to next message
Norbie wrote on Mon, 25 October 2004 16:01
Whereabouts should i look for the drivers side airvent? Do you mean the air intake, or something like that? I'm confused.
Could it possibly be something to do with this louvre ?
http://img92.exs.cx/img92/157/Celica_004.jpg
omegaman
SYDNEY
Re: Leaks in my ra28 Mon, 25 October 2004 09:21 Go to previous messageGo to next message
I've had a similar problem. It could be 2 factors.
1. your windscreen rubber may have joins on the corners, these may have started to split, therefor it leaks. or
2. the chrome moulds around the screen are held on by metal clips. These may have rusted and swollen.
i tried heaps of sealant, I even took out the clips and put sealant and it still didn't work. new rubbers professionally fitted.
chrishulbert
Castle Hill NSW
Re: Leaks in my ra28 Mon, 25 October 2004 10:56 Go to previous messageGo to next message
I don't really want to fit new rubbers, as i have a suspicion that if someone takes the windscreen off there might be a stack of rust in there, which i reeeeeally dont want to have to fix.
I'll try sealing up the windscreen though... i've only made a halfassed effort at sealing it so far, so if i do it properly i might hit paydirt.
M.W.P.
Rocky Mountains, Canada
Re: Leaks in my ra28 Mon, 25 October 2004 11:47 Go to previous messageGo to next message
Any sign of rust around the front of the car?
Ive had a rust hole in the box area where the wipers are cause water to drip onto my accel foot.
chrishulbert
Castle Hill NSW
Re: Leaks in my ra28 Mon, 25 October 2004 14:12 Go to previous messageGo to next message
M.W.P. wrote on Mon, 25 October 2004 21:47
Thats exactly where it drips in my car !!
But no i can't see any rust anywhere - i don't know how to look inside the "box area" anyhow - i took the wheel guards off and that didn't get me anywhere.
CLG
Perth, Western Australia
Re: Leaks in my ra28 Mon, 25 October 2004 15:44 Go to previous messageGo to next message
Pull the windscreen out, check the rubbers, and re seal it properly!
chrishulbert
Castle Hill NSW
Re: Leaks in my ra28 Mon, 25 October 2004 23:23 Go to previous messageGo to next message
Isn't that a really really *really* hard job to do? Sad
Gleno28
Re: Leaks in my ra28 Tue, 26 October 2004 00:36 Go to previous messageGo to next message
I actually had two RA28's, both leaked in the front windscreen seal and the rear screen seal... basically because of the old rubber splitting at the joins. I had new screen rubbers put in which worked v.well, but still have some leaks from door rubbers which leaves wet carpet near the acc pedal. Also the rear small windows tend to leak down under the back seat and onto the floor there... lots of new rubbers needed $$$ for me
To fill joints i found sikaflex (yuk) worked ok and some '?Gold' stuff, as long as the don't go hard and crack in the sun
Have fun
RA28
Re: Leaks in my ra28 Tue, 26 October 2004 03:40 Go to previous messageGo to next message
I got a front windscreen rubber from rare spares for $110 a coupla years ago. The rubber was one piece so no corner joins like the factory one. Just take it to a window guy I'd suggest...
Tim.
gold28
Madrid - Spain
Re: Leaks in my ra28 Wed, 27 October 2004 10:41 Go to previous messageGo to next message
As Norbie said, check your air vent.
I bet you get a sock full of it when you go around a left hand corner. Very Happy
In the photo you put up earlier, under this grill is the Plenum chamber. Stick your hand in there and feel around for rust holes. Often bits of leaf and crap get in and rot away in there giving a perfect environment for rust to occur.
Problem is this is a horrid place to fix rust cos you can't get to it. Rolling Eyes
chrishulbert
Castle Hill NSW
Re: Leaks in my ra28 Wed, 27 October 2004 23:34 Go to previous messageGo to next message
So, whereabouts do i check the air vents?
gold28
Madrid - Spain
Re: Leaks in my ra28 Thu, 28 October 2004 10:01 Go to previous messageGo to next message
chrishulbert wrote on Thu, 28 October 2004 09:34
gold28 wrote on Wed, 27 October 2004 20:41
chrishulbert
Castle Hill NSW
Re: Leaks in my ra28 Thu, 28 October 2004 23:32 Go to previous messageGo to next message
Smaaaaaaaaart man.
chrishulbert
Castle Hill NSW
Re: Leaks in my ra28 Wed, 10 November 2004 22:22 Go to previous message
Ok i finally checked the air vents. Couldn't fit my arms in there, but i got the hose and blasted heaps of water through there, and none leaked into the car.
Any other ideas?
Previous Topic:blown bottom end bearing ?
Next Topic:Stud removal/replacement in sprinter.
Current Time: Fri Oct 16 13:04:47 UTC 2026
Total time taken to generate the page: 0.0071120262145996 seconds
