Toymods » Tech & Conversions » Gasoline smell inside Celica TA23 '77 2TB engine
stevenvandecauter
Belgium
Gasoline smell inside Celica TA23 '77 2TB engine Mon, 25 October 2004 09:20 Go to next message
Yesterday, I went for a 250 Km. trip on secondary roads in a Celica TA23 2TB.
At red lights (in front of which I stop ;-> ), I noticed a gasoline smell coming throught the ventilating system.
Going a bit into RPM's (still idling at light 2000 RPM) seemed to stop this problem.
Timing is set at 2 degrees advance (should be 10 or 12 factory I think) because it then starts better.
Also, when driving at constant speed, the car 'shocks' a bit, it is not very noticable, but you can feel it in the accelerator pedal. Using the choke at that moment seems to cure that chocking, but I guess then the mixture is too rich for a warm engine ?
I'm not at all a mechanic, but does somebody know whether above symtoms are related and knows what could be done to cure them, please ? Could it be the carburator that needs adjustments or something else, like the fuel filter, ???
Steven
TA-022
Glenmore Park, NSW
Re: Gasoline smell inside Celica TA23 '77 2TB engine Fri, 29 October 2004 09:48 Go to previous message
i get the same *chocking* in my 2t.
ran fine for the first 3 months i had it then developed a loping idle .... and its not a air leak.
i suspect damaged valve seats on mine.
yours ... having the fuel odor i suspect over rich and under timed as u say ur spark is retard quite a bit, so i expect exsess fuel vapour. Not sure on the 2tg but if u run a charcoal canister it could be that it is blocked and the vapours are thereby escaping to the engine bay... then into ur vents?
food for thought.
Nathan
Previous Topic:Dual Aisans side draft on 1971 Corona Mk11 coupe RT72 with 8RB
Next Topic:22R, or 1GGTE???
Current Time: Fri Nov 20 12:42:44 UTC 2026
Total time taken to generate the page: 0.004633903503418 seconds
