Toymods » Tech & Conversions » 4AGE wiring in to Ke20
twincam_ke20
Castlemaine Vic
icon5.gif  4AGE wiring in to Ke20 Tue, 26 October 2004 09:20 Go to next message
hey all,
just wondering how hard this will be to do?
anyone else done it? I wanna use the stock computer if possible, if not, I'll go microtech.
should i just go to aftermarket from the beginning?
or will it be easy enough with the stock ecu/loom of the 4age.
Re: 4AGE wiring in to Ke20 Tue, 26 October 2004 09:52 Go to previous messageGo to next message
sicne the KE20 has virtually no loom to begin with, just start with the 4AG's looms and make new wiring from there...
since you are basically starting from a clean slate, it will be pretty easy.. i'm doing similar into KE1X atm.. redoing whole wiring so it actually has relays Wink
twincam_ke20
Castlemaine Vic
Re: 4AGE wiring in to Ke20 Tue, 26 October 2004 10:39 Go to previous messageGo to next message
stu, so like, re-wire the whole car ya mean?
i just wanna get it in there and running (it sounds a bit rip,tare,bust i know Confused )
so wold it be hard to wire in to the small ke20 loom?
Re: 4AGE wiring in to Ke20 Tue, 26 October 2004 10:42 Go to previous messageGo to next message
well, you don't have to do anythign so drastic...
something like...
wire ignition switch to a main relay, have that relay turn on ones for fuel pump, coil, injectors/ECU etc... and basically install an "EFI loom" as such... try not to load the ignition switch any more than it is now by relaying all power..
you can keep the indicators etc wiring seperate, but now would be a good opportunity to relay the headlights, and thermofan too.
you could also wire in an immobiliser and central locking Wink
bmak
Re: 4AGE wiring in to Ke20 Tue, 26 October 2004 12:18 Go to previous messageGo to next message
Its pretty simple with the stock 4ag computer.
Only need constant power, Ign power & start power.
All the rest is contained in the 4ag loom.
The only other thing is the power to & from the fuel pump relay.
EvilJack
Sutho/Hills NSW
Re: 4AGE wiring in to Ke20 Tue, 26 October 2004 12:52 Go to previous message
http://www.insertdomainnamehere.com/misc/KE20%2020 V%20Install/
Previous Topic:Wiring diagram for pioneer DEH-P4050
Next Topic:1jz Cressie tranny fixed...ahh the frustration
Current Time: Sat Oct 24 14:56:42 UTC 2026
Total time taken to generate the page: 0.20222091674805 seconds
