Toymods » Tech & Conversions » Need advice on fitting a Hiper boost controller to 1G
BLK1GGTE
South Eastern Subs
icon10.gif  Need advice on fitting a Hiper boost controller to 1G Tue, 26 October 2004 09:28 Go to next message
Hi has anyone fitted Hiperboost controller to a 1ggte..if so do u have pics..i am just a little confused on how to do it...new to this turbo thing..do i block one of the copmressor outlets..then put the other end into the wastegate controller and then mount the other end of the wastegate controller into the intake pipe after the cooler..err anything like this..
http://www.supras.org.nz/techinfo/johnathan_walker /Stg2.htm
Anyways advice and pics would be great cause i am itching to put it on...Thanks peoples
3t-RA40
Re: Need advice on fitting a Hiper boost controller to 1G Tue, 26 October 2004 11:04 Go to previous messageGo to next message
Send an e-mail to sales@hiperboost.com or contact Paul Holmes directly on 0425 750 038 and ask for instructions if you didn't get any with the product. I know he will help out.
[Updated on: Tue, 26 October 2004 11:08]
Chris Davey
sunny coast, qld
Re: Need advice on fitting a Hiper boost controller to 1G Tue, 26 October 2004 12:37 Go to previous messageGo to next message
I am pretty sure that the ct12's are the same as ct12a's so...
you get the line from each compressor housing and t-pice them together and you do the same with the two hoses from the wastegate actuators and if I remember correctly, the compressor housing pipe goes to the barbed connector and the wastegate hose goes to the smaller black connector. And the you have the really small one which is the in cabin control with the fine tune knob on it.
I think that is it, but I am sure Paul will clear anything up.
Jag7799
Re: Need advice on fitting a Hiper boost controller to 1G Tue, 26 October 2004 12:45 Go to previous messageGo to next message
Chris Davey wrote on Tue, 26 October 2004 22:37
thats it for sure
Compressor outlet of both turbo's into T.. from T into barbed connector.. Plastic connector to T and then from that to Both wastegate actuators
BLK1GGTE
South Eastern Subs
Re: Need advice on fitting a Hiper boost controller to 1G Tue, 26 October 2004 14:41 Go to previous messageGo to next message
like this guys has done on this page..
Jag7799
Re: Need advice on fitting a Hiper boost controller to 1G Tue, 26 October 2004 14:51 Go to previous messageGo to next message
dont plug up anything
BLK1GGTE
South Eastern Subs
Re: Need advice on fitting a Hiper boost controller to 1G Tue, 26 October 2004 16:48 Go to previous messageGo to next message
err..what u mean..anyways i think i figured it out and i call paul tomorow to make sure...
Jag7799
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 00:59 Go to previous messageGo to next message
what that guy is doing is blocking off 1 compressor outlet(as far as i can tell.. and is using only 1 for the boost pressure.. and then putting 2 outputs to wastegates.
The boost controller wont work effectively in that way I dont beleive.
Just do it how we said
Take 2 lines(i think its 1/4 inch fuel line hose you want) from the compressor outlets .... on second thoughts... give me 30 mins.. and ill make it SO clear for you. Smile
HyDrA
Adelaide, SA
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 01:11 Go to previous messageGo to next message
No, he blocks up both compressor outlets and uses the pressure after the intercooler (ie. combined pressure of both turbos). It is supposed to come on boost quicker this way too... apparently!
Jag7799
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 01:30 Go to previous messageGo to next message
...... t-ing both the outlets uses the pressure from both turbo's.. give me 15 mins more.. and there will be a nice healthy diagram
and not a cheapo on either
HyDrA
Adelaide, SA
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 01:37 Go to previous messageGo to next message
Yeh, thats another way to do it... There are heaps of ways to do the same or similar thing. Each will have different results.
I am awaiting your diagram.
Jag7799
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 01:44 Go to previous messageGo to next message
HERE
http://members.optushome.com.au/jag7799/car/turboinst.jpg
[Updated on: Wed, 27 October 2004 01:45]
HyDrA
Adelaide, SA
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 01:46 Go to previous messageGo to next message
That is an awesome diagram!!
Someone buy this man a beer... or 24!
Jag7799
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 01:47 Go to previous messageGo to next message
explain?
I started this for Paul a few months ago.. had most of it there.. just decided to finish it a little bit..
could make it better.. but thats enough for now
[Updated on: Wed, 27 October 2004 01:48]
HyDrA
Adelaide, SA
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 01:48 Go to previous messageGo to next message
I was saying, I like the diagram.
Rolling Eyes
Jag7799
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 01:50 Go to previous messageGo to next message
HyDrA wrote on Wed, 27 October 2004 11:48
Rolling Eyes
i know hehe..
but it explains it all well enough for people who have never done it before to understand, do you think?
HyDrA
Adelaide, SA
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 01:55 Go to previous messageGo to next message
Yes, it doesnt get too much simpler really!
Colours and all will help the newbies a lot thats for sure. Lets just hope they bother to install a plumb back BOV before they go boost crazy Confused
Jag7799
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 01:57 Go to previous messageGo to next message
HyDrA wrote on Wed, 27 October 2004 11:55
i BET one day ill get someone come up to me and go "what do you do if you dont have blue and yellow hose"
ill cry
indian
south east - melbourne
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 02:08 Go to previous messageGo to next message
ok what the thing on the left side of the boost control box , looks like a optical audio output , Confused Confused Confused Confused Confused
Jag7799
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 02:20 Go to previous messageGo to next message
its the boost controller fine control.. its part of the boost controller.. which lets you adjust by .5 of a psi
but yes, it does look like optical cable
HyDrA
Adelaide, SA
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 02:29 Go to previous messageGo to next message
Leave the poor optical cables alone Crying or Very Sad Poor little guys always get abused!!
Laughing
BLK1GGTE
South Eastern Subs
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 03:24 Go to previous messageGo to next message
Jag7799 U are one champion..thats a crazy graph..thanks it makes it soo much more clearer...but
can't i instead of T pieceing the Wastegates, Plug one of the wastegates in the controllers into Wastegate 1 and the other in Wastegate 2...(its on the other side of the controller where the little fine hand controller is..it comes pluged with this red blanking plug
So the wastegate controller is just pluged after the T piece in beetween the unit and t piece
By the way thatnks for the help everyone
Jag7799
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 03:36 Go to previous messageGo to next message
BLK1GGTE wrote on Wed, 27 October 2004 13:24
im not sure if he made that work in the newer models..
how new is ur controller.. just make sure it is in.. and yes u can do it that way.. he changes his design so often Smile
MR 1JZ
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 03:42 Go to previous messageGo to next message
Yo Jag sick diagram man, anyway how would I hook it up if i was just using a plan old bleeder valve?
Do I put both blue hoses together on the inlet side of the bleeder and both yellow hoses together on the outlet side of the bleeder?
BLK1GGTE
South Eastern Subs
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 03:45 Go to previous messageGo to next message
Yeah its got an outlet for the seccond wastegate...i just brought the controller yesterday so spaknkers..By the way thanks for the diagram..big help..
Jag7799
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 03:47 Go to previous messageGo to next message
okay.. then yes.. instead of second t peice to wastegate.. just run a line to each of the plugs(are u sure its wastegate line? and not inlet)..
Mr 1g gte.. its exactly ther same.. t the outlet into inlet of controller.. form controller outlet to T to wastegate's
BLK1GGTE
South Eastern Subs
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 03:52 Go to previous messageGo to next message
Yeah..Its got Wastegate 1 and compressor outlets on one side, and Wastegate 2 and the hand controller on the other...
Do you think there is any benefits getting pressure signal for the wastegate controller from the intercooler side..(after the cooler like in that link i first posted) Just curious... Pauls said only if you have a restrivtive cooler..but i got a HKS aftermarket cooler so you think anything to be gained by Pluming it this way??
Just thought i get some opinions since everyone seem to know lots about these things here??
MR 1JZ
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 03:57 Go to previous messageGo to next message
cheers jag Very Happy
Jag7799
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 03:59 Go to previous messageGo to next message
BLK1GGTE wrote on Wed, 27 October 2004 13:52
i very much doubt it.. I dont see how it would give you any gains at all.. all u want to do is control the boost.. and from the compressor outlets your getting it straight from both turbo's(the combined air) where as on other side of cooler you will have to have long lines which i "beleive" would cause lag and spikes.. but im not sure
BLK1GGTE
South Eastern Subs
Re: Need advice on fitting a Hiper boost controller to 1G Wed, 27 October 2004 04:19 Go to previous message
Makes good sence well thanks again for the graph...cheers
Previous Topic:Opinions on this baffling
Next Topic:5K Modifcations in a KE26
Current Time: Wed Oct 28 05:54:01 UTC 2026
Total time taken to generate the page: 0.0074501037597656 seconds
