Toymods » Tech & Conversions » Opinions on this baffling
Opinions on this baffling Tue, 26 October 2004 11:25 Go to next message
http://img33.exs.cx/img33/5584/baffledsump.jpg
Hi all, what do you think of the baffling in this sump? I am thinking of this for the 3tgte sump to help with some track work. This design has come from someone who used to run a modified 18rg in improved production racing and said has had very good results.
Joel
bbaacchhyy
Re: Opinions on this baffling Tue, 26 October 2004 11:37 Go to previous messageGo to next message
Hard to say without having a closer look. The main thin gis to ensure the oil has a way of easily getting in, but has trouble getting out.
Some of the really fancy ones use sprung loaded trap doors.
Mind you if it worked on the track, then it should be OK. Can it be proven that it worked though ?
Michael B
CelicaRA45
nth ringwood, Victoria
Re: Opinions on this baffling Wed, 27 October 2004 04:44 Go to previous message
on the 2tg we also had door hinges and another baffle 25mm down from the top of the sump to stop the oil hitting the crank and also a windage tray bolted to the block with slots in it just enough room for the rods and crank to rotate
Previous Topic:Wheel weight reduction steeel->alloy
Next Topic:Need advice on fitting a Hiper boost controller to 1G
Current Time: Thu Oct 29 09:50:10 UTC 2026
Total time taken to generate the page: 0.026286125183105 seconds
