Toymods » Tech & Conversions » Timing Belt - 4AGE Smallport
bourny
Timing Belt - 4AGE Smallport Wed, 27 October 2004 00:36 Go to next message
Hey guys,
I snapped the timing belt in my rolla last night, just a quick question, i've been told its very likey that i have bent / snapped the valves.
Just wondering if anyone has snapped the timing belt in a 4AGE before and how common it is to bend or snap valves.
Also what sort of process you went through to fix the problem.
I was told i should get the valves reseated and head machined while its off.
Can someone just give me a insight of the process of replacing belt and fixing valves / head if needed.
CHeers
Bourny
takai
Re: Timing Belt - 4AGE Smallport Wed, 27 October 2004 00:38 Go to previous messageGo to next message
Most 4AGEs are non-interference unless it has been modified fairly heavily.
Re: Timing Belt - 4AGE Smallport Wed, 27 October 2004 00:40 Go to previous messageGo to next message
Yeah like Takai said.. it is unlikely you have bent any valves.
Just get a new belt, line up all the timing marks and away you go.
bourny
Re: Timing Belt - 4AGE Smallport Wed, 27 October 2004 01:25 Go to previous messageGo to next message
Thanks for your replys..
So most 4AGEs are non interference? thats means its unlikey i did any damage to the engine with the belt snapped?
Cool.. i hope you guys are right..
Anything else i should get done when putting the belt on?
bourny
feral4mr2
Bundaberg, Qld.
Re: Timing Belt - 4AGE Smallport Wed, 27 October 2004 03:14 Go to previous messageGo to next message
a new timing belt idler/tensioner.
Re: Timing Belt - 4AGE Smallport Wed, 27 October 2004 03:57 Go to previous messageGo to next message
You probably would have heard some great sounds if you actually did some damage Very Happy
Shraka
Re: Timing Belt - 4AGE Smallport Wed, 27 October 2004 04:24 Go to previous messageGo to next message
Yeah, if it wasn't/isn't a non-interference engine the valve would have slammed into the piston. This bends the valve, and also smashes a nice hole in the top of your piston. Also make a very bad sound (not that I would know, I've only seen the aftermath, but I've been told).
So if you have bent your valves (and you probably haven't due to yeah, non-interference engine) it would probably be full engine rebuild / replacement time.
b1gb3n
south Melbourne/KL
Re: Timing Belt - 4AGE Smallport Wed, 27 October 2004 05:48 Go to previous messageGo to next message
4ages are known to roll their way to workshop after belt snaps. all they do is cchange belt and off u go!! Common for 4ages
bourny
Re: Timing Belt - 4AGE Smallport Sun, 31 October 2004 03:48 Go to previous messageGo to next message
Ok, i replaced the timing belt, and still won't start. i have no idea.
Did a compression test and it was very low on all cylinders, 80 80 90 100....
I'm thinking i did bent / snap the valves, otherwise what would cause these low compressions?
I have checked everything, please help.. ASAP!!!
Bourny
feral4mr2
Bundaberg, Qld.
Re: Timing Belt - 4AGE Smallport Sun, 31 October 2004 08:55 Go to previous messageGo to next message
did you line the cams up correctly with the engine at TDC?
b1gb3n
south Melbourne/KL
Re: Timing Belt - 4AGE Smallport Sun, 31 October 2004 09:01 Go to previous messageGo to next message
i have a problem too. i changed my cams, put the cam gears and belt in to exact location (marked gears and belt b4 removing).
After cranking engine one cycle by hand, the marks dont meet. Probably due to belt tension change. How do i overcome this problem??
bourny, u sure u didnt put cam gears up side down?? Maybe u have same problem as me.
takai
Re: Timing Belt - 4AGE Smallport Sun, 31 October 2004 10:49 Go to previous messageGo to next message
Just keep retensioning the belt, it may be out by like one tooth. Also its two cycles of the crank to line it up.
allencr
tallahassee FL usOFa
Re: Timing Belt - 4AGE Smallport Sun, 31 October 2004 13:22 Go to previous messageGo to next message
timing - cam/s and or ignition.
the compression is not too low to be able to run, and is too high & consistant for bent valves.
b1gb3n
south Melbourne/KL
Re: Timing Belt - 4AGE Smallport Sun, 31 October 2004 14:38 Go to previous messageGo to next message
takai wrote on Sun, 31 October 2004 21:49
will try 2 cycles. my mistake.
Which part of melbourne are u?? Rolling Eyes Rolling Eyes
bourny
Re: Timing Belt - 4AGE Smallport Sun, 31 October 2004 23:24 Go to previous messageGo to next message
Thanks guys, ill check the timing again also the cams at TDC...
what would cause the low compression? bottom end wearing out?
Ill check these things today and ill let you guys know what happens...
i ready to get rid of this car, i just want something more reliable but i don't have the money to buy one yet...
Cheers guys.
Bourny
DJR_
Re: Timing Belt - 4AGE Smallport Mon, 01 November 2004 00:51 Go to previous messageGo to next message
If you think you have bent valves, check your valve clearances, they will be way out of spec if they are.
4a's are non-interference though, so you shouldn't have a problem. Just line up all you cams and make sure after 2 crankshaft revs it's all still lined up.
takai
Re: Timing Belt - 4AGE Smallport Mon, 01 November 2004 02:21 Go to previous messageGo to next message
East, near Nunawading.
Re: Timing Belt - 4AGE Smallport Mon, 01 November 2004 03:19 Go to previous messageGo to next message
also, make sure you have your cam timing set in reference to TDC COMPRESSION stroke....
On the stock cams, there is actually a little notch up the front of the shaft which denotes TDC compression, have these notches on both cams pointing straight up, and then put on the cam gears so that the notches on the cam gears line up with the lines on the timing cover back plate.
Now line up the crankshaft to TDC, there are notches on both the timing gear drive and the crank pullet.
Install belt, and make sure you have enough tension that after a few revolutions (i do about 6) everything is still lined up at TDC compression.
Easy peasy. I dont understand why people get confused doing this....
bourny
Re: Timing Belt - 4AGE Smallport Mon, 01 November 2004 05:45 Go to previous messageGo to next message
THE WITZL - Thanks mate, we all can't be as smart as you.. i'm still learning, its a long battle, and guys like you are always a good source of infomation.
So thanks for the help and ill be trying to start the bugger tomorrow, so ill let you guys know how it goes..
Cheers for now..
Bourny
b1gb3n
south Melbourne/KL
Re: Timing Belt - 4AGE Smallport Mon, 01 November 2004 06:12 Go to previous messageGo to next message
THE WITZL wrote on Mon, 01 November 2004 14:19
hey!! first timer here!! considered adventurous to go ahead by my self alright!!!
Re: Timing Belt - 4AGE Smallport Mon, 01 November 2004 06:55 Go to previous message
hey, im only a 3rd timer!
you know what you do - go HERE: http://www.toymods.org.au
# Tech Docs
Previous Topic:1g alternator wiring + wiring testing
Next Topic:Camry altise Qustion
Current Time: Sat Oct 17 08:06:14 UTC 2026
Total time taken to generate the page: 0.007767915725708 seconds
