Classifieds » Miscellaneous » FS: 4AGE Carby Manifold
IRA11Y
Club Member
FS: 4AGE Carby Manifold Thu, 03 October 2002 10:27 Go to next message
I have a custom made carby manifold to suit a bigport 4AGE, will suit Weber, Dellorto and Solex side draft carbs $150 ONO will put some pics up by the weekend
Ribbo
Northern Beaches
Re: FS: 4AGE Carby Manifold Thu, 03 October 2002 11:30 Go to previous messageGo to next message
whats would the reason to convert from efi to carby? sounds like a downgrade to me
Johnny
Sydney, OZ
Re: FS: 4AGE Carby Manifold Thu, 03 October 2002 11:39 Go to previous messageGo to next message
I wouldn't let Rod read that! You could be in for more than you think.
Anyway, Mick I'll have a looksy, I had a guy want to upgrade, but EFI was going to be too expensive.
Johnny
IRA11Y
Club Member
Re: FS: 4AGE Carby Manifold Fri, 04 October 2002 13:05 Go to previous messageGo to next message
spoken like someone who's really done thier research Smile, in actual fact under certain conditions a carby will mix air and fuel better than an injector can. Let me know what you think of carbies next dyno day Ribbo, then we can discuss if its going backwards or not Razz
John you can come grab those pistons anytime you like
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: FS: 4AGE Carby Manifold Fri, 04 October 2002 13:40 Go to previous messageGo to next message
No Message Body
[Updated on: Sun, 06 October 2002 12:19]
IRA11Y
Club Member
Re: FS: 4AGE Carby Manifold Fri, 04 October 2002 21:41 Go to previous messageGo to next message
Im confused.. is this a Tech page or a For Sale page??
heres some pics...
http://ira11y.qnix.com.au/Carb%20Manifold.jpg
http://ira11y.qnix.com.au/Carb%20Manifold%202.jpg
[Updated on: Sat, 05 October 2002 06:14]
Ribbo
Northern Beaches
Re: FS: 4AGE Carby Manifold Sun, 06 October 2002 03:10 Go to previous messageGo to next message
hehe ok well ill have to see next dyno day then Smile
TRUEN0
Akina
Re: FS: 4AGE Carby Manifold Sun, 06 October 2002 06:50 Go to previous messageGo to next message
interest...
trd086@hotmail.com
i am in melbourne..
i want more info abt it.
kingmick
Banned by his request
moved to tamworth
Re: FS: 4AGE Carby Manifold Sun, 06 October 2002 11:18 Go to previous messageGo to next message
haha mick! a bucket with wholes can never mix aswell as proper efi. injectors can be faced up{better fuel economy} or down{grunt}. we have the trumpets designed for perkins bathurst car a few years ago and he got one less fuel stop by aiming the injectors up and out the trumpets. creates a big fuel cloud in the airbox{you just have to hope for no backfire} which could never be match by a carbie. there are a thousand reason, drivablility, dont have to change jet all the time for atmo pressure etc. the carb manifold would make a great start to a quad thottle body injection manifold. would buy it myself if i wasnt blown.
mick p.s carby or efi make the same power most of the time just efi much more drivablity and better response and alot more option with traction control and the like
[Updated on: Sun, 06 October 2002 11:21]
IRA11Y
Club Member
Re: FS: 4AGE Carby Manifold Sun, 06 October 2002 11:50 Go to previous messageGo to next message
Guys Ive got no problem discussing this in a technical format..but can we do it in the technical section.... or should we all just start questioning each others for sale items for the hell of it!!! for christ sake I just posted an item for sale I never asked for this debate!!
Mick..youre comparing apples with oranges and Im happy to discuss why you are not completely correct if you want to start a thread in technical..if you guys continue to post tech information here Ill ask for the thread to be deleted.
Now please give those that may actually be interested in this item a chance before you start baging them for being interested as well!!!
Trueno...what do you want to know?
TRUEN0
Akina
Re: FS: 4AGE Carby Manifold Sun, 06 October 2002 13:05 Go to previous messageGo to next message
is it easy to send over to melbourne?
does it fit 88kw 4AGE?
straight fit in?
Very Happy
IRA11Y
Club Member
Re: FS: 4AGE Carby Manifold Mon, 07 October 2002 01:13 Go to previous messageGo to next message
Trueno
Yep its easy to send to melbourne, being alloy its nice and light so freight shouldnt be too much either.
Yes the manifold is to suit a bigport 4AGE
Yes it bolts straight on to the existing bolt pattern, you will have to block off the injector ports on the head somehow though and most likely use some shorter studs as the factory ones are a little too long and will not allow you to bolt it up properly, you can use a standard intake gasket to seal it. you will also have to remove the two little dowls from the two stud points, off centre at the top, its easy to do with a pair of pliers.
thetoyman75
Club President
Re: FS: 4AGE Carby Manifold Mon, 07 October 2002 02:32 Go to previous messageGo to next message
Ribbo and Kingmick,
Firstly guys I must say it bad form to have a go at something someone has for sale. You wanna argue this sort of thing head over to tech and conversions !
Secondly you two need to open your eyes to the wider world of fuel delivery. A well set up set of carbies as per this style manifold (1 carby barrel and thoat per cylinder) will in some cases outperform a EFI set up that uses your standard configeration.
Ever wondered why Individual throttlebody EFI was invented ?? To try and get EFI to the perfomrance level that can be acheived from a good set of carbies. But anyway this is NOT the place.
Just for reference the performance my 4AGE was stock all bar the cams that actually had less lift than the stock 4AGE cams, (7.1mm....Go figure ? ) if carbies are so bad how come my results compare so well to the other 4AGE's at Dyno day 3 ?
Ribbo
Northern Beaches
Re: FS: 4AGE Carby Manifold Mon, 07 October 2002 07:53 Go to previous messageGo to next message
2 things, I have started the thread in the Tech section as I want to know.
and I never had a go at what was being sold I just asked why u would go carby over efi? out of curiosity. If a good reason comes up then it should be advantages to the seller.
[Updated on: Mon, 07 October 2002 07:55]
kingmick
moved to tamworth
Re: FS: 4AGE Carby Manifold Mon, 07 October 2002 09:08 Go to previous messageGo to next message
it was only the old bucket and the throttlebody hard time.
mick ill pick it up saturday if no one gets it first.
mick. a
IRA11Y
Club Member
Re: FS: 4AGE Carby Manifold Thu, 17 October 2002 06:05 Go to previous message
SOLD
Previous Topic:Bits To Suit Swift
Next Topic:FS: Prelude bucket seats. Excellent condition.
Current Time: Tue Oct 27 07:55:08 UTC 2026
Total time taken to generate the page: 0.010210037231445 seconds
