Toymods » Tech & Conversions » 1jz overheating
supra86
1jz overheating Wed, 27 October 2004 05:40 Go to next message
I found my car was overheating (or that is what my gauge is telling me) when I was in the freeway doin around 140k/ph, within 1 minute the gauge would rise to the top and as I slow down the gauge would drop back down to normal.
Been to a couple of mechanics some say it's the:
1. Thermostat or turbo water line or some shit faulty. But I know it's not overheating to the max cos I pop the bonnet immediately after I saw the temp. at the gauge, the reservoir was warm n hoses are too.
2. block radiator - if it's block the car will overheat in traffic in winter or summer (constant stop, start) but it doesn't
3. faulty temp. sensor or gauge. Don't know how to check.
Any ideas would be great
many thanks
[Updated on: Wed, 27 October 2004 05:43]
RAV-GT4
Toymods member
Rydalmere, NSW
Re: 1jz overheating Wed, 27 October 2004 06:06 Go to previous messageGo to next message
How long has it been since the coolant has been changed over?
supra86
Re: 1jz overheating Wed, 27 October 2004 06:14 Go to previous messageGo to next message
6 months.
toyota coolant
lumpy
Adelaide, SA
Re: 1jz overheating Wed, 27 October 2004 07:04 Go to previous messageGo to next message
It's not running lean at higher rpm?
Also, do you have the jza70 radiator and fan assembly - with fan control computer working properly (although low fan speed usually causes overheating when going slowly/idling).
Have you bled the air out of the system?
Danish
Re: 1jz overheating Wed, 27 October 2004 07:39 Go to previous messageGo to next message
Agree with lumpy, it could be running too lean on the highway. Adding more fuel will stop that.
Should be running at 92C, and I hope your fan setup works fine.
supra86
Re: 1jz overheating Sun, 07 November 2004 12:49 Go to previous messageGo to next message
thanks and sorry for late response, having problems with the net.
the fan control unit is fitted connected to the rad. temp sensor.
can't be lean too cause i put her on the dyno months ago and the AFR:P was 10.2 at 150kph
lumpy
Adelaide, SA
Re: 1jz overheating Sun, 07 November 2004 23:57 Go to previous messageGo to next message
supra86 wrote on Sun, 07 November 2004 23:19
That AFR would have been at WOT though, from your description of the problem it's happening under light load/cruise. Could be a faulty gauge - try hooking an aftermarket one up (if only temporarily) to see what happens. Has the raidator been flushed or cleaned since you put the engine in? (I'm guessing it's the jap radiator).
supra86
Re: 1jz overheating Mon, 08 November 2004 08:15 Go to previous messageGo to next message
yep, the radiator and the car is jap.
i flushed it not long ago
sorry what i meant was it overheat when i WOT (full std boost 9psi) at that speed but as soon as i back off. the temp start dropping back to normal
most likely i will put some sort of aftermarket temp gauge and see what happens. and hope it's a faulty gauge but i doubt it.
thanks lumpy
lumpy
Adelaide, SA
Re: 1jz overheating Mon, 08 November 2004 22:25 Go to previous messageGo to next message
Ahhh... mine did that with the jap raditor when at WOT for a longish period of time (like a blast up the hills). I got the radiator pulled apart and cleaned - found it was blocked with a lot of shit and not working effectively. Apparently just flushing out doesn't remove all of the crap, they pull the radiator apart (top and bottom tanks removed) and use long brushes to clean out the core. I never noticed it overheating in the summer time in traffic, only when flat out for a period of time - as the heat load on the engine is much higher at WOT even though there is more airflow over the radiator.
In the end, I got a new radiator because the top tank on my jap one was cracked and they couldn't find another one to fit (a whole new long and expensive story).
wilbo666
Re: 1jz overheating Tue, 09 November 2004 03:39 Go to previous message
I'd be looking at the radiator as well.
When my car was overheating at highway speeds (and not around the city) it was a clogged radiator.
Previous Topic:What are these three gearboxes?
Next Topic:18rc big bore pistons
Current Time: Mon Oct 19 17:50:35 UTC 2026
Total time taken to generate the page: 0.0054740905761719 seconds
