Toymods » Tech & Conversions » Better economy - custom manifold
cplux
Better economy - custom manifold Wed, 27 October 2004 12:07 Go to next message
Hi all I'm chasing suggestions/opinions on how to gain some better economy in my supercharged 4 cyl 4y-c hilux.
Current setup is using ea falcon throttle body injection, wolf3d computer and sc14 charger. According to the guy who tuned it up these injectors are running flat out at high revs (he actually said he is driving em 130% of wolf max setting). In regards to this i have no idea what the actual rated flow of these is but they are off a 3.9l six cyl. I am also mainly as a temp solution running water injection. (done post tune)
Firstly I am going to intercool it with a liberty water/air cooler. Car had alot of problems with pinging when dynoed as air temps soared. Hopefully i can reduce fuel rate alot if charged air is cooler.
I was also thinking of using a 4y-e inlet manifold & injectors (possibly upgraded to whatever ijectors will fit), so i can have an injector per cylinder. This will also require changing to dual pulse ign signal. Problem with this is i will have to custom make the plenum/throttle body part as the 4y-e one will stand too high in the engine bay for intercooler and also the air intake would be on the wrong side. Suggestions??
It was also suggested to me by the mechanic to run dual coil or better yet direct fire ignition, instead of the current dizzy/signal coil/pulse setup.
http://img.villagephotos.com/p/2004-10/867412/eathrottlebody.JPG
http://img.villagephotos.com/p/2004-10/867412/efimanifold.JPG
http://img.villagephotos.com/p/2004-10/867412/efiplenum.JPG
[Updated on: Wed, 27 October 2004 12:08]
cplux
Re: Better economy - custom manifold Wed, 27 October 2004 12:12 Go to previous messageGo to next message
http://img.villagephotos.com/p/2004-10/867412/4yc-supercharged.jpg
pic of current setup
pic of 4y-e
http://img.villagephotos.com/p/2004-10/867412/4y-E1.JPG
[Updated on: Wed, 27 October 2004 12:14]
Re: Better economy - custom manifold Wed, 27 October 2004 13:45 Go to previous messageGo to next message
First up, PLEASE bin that horrible Falcon 'electric carb' - NOW!
You could well use the 4Y-E manifold, but it would probably also not be too difficult to make something up that better fits in with everything, that's if you're handy with the welder, grinder, etc. Otherwise, it might get a bit expensive paying someone else!
RA28
Re: Better economy - custom manifold Wed, 27 October 2004 14:36 Go to previous messageGo to next message
If you have a fairly simple direct injection manifold ( I have nfi about "Y" engines...) then for sure swap to that. You should get more power, which will translate to economy if you lift your foot Smile
For god's sake, get an intercooler... more power for sure and if the tuner richened the mixture to try to combat the detonation then you'll pick up fairly large increases in economy. you may also get the oppertunity to wind up the boost Smile
Tim.
cplux
Re: Better economy - custom manifold Wed, 27 October 2004 20:31 Go to previous message
pic of my existing manifold that falcon throttle body bolts to.http://img.villagephotos.com/p/2004-10/867412/carbmanifold.JPG
Previous Topic:suspension for my 86
Next Topic:TA22 brakes
Current Time: Thu Oct 29 07:15:11 UTC 2026
Total time taken to generate the page: 0.015233993530273 seconds
