Toymods » Tech & Conversions » 84 supra (turbo) manual conversion
turbosupra
Liverpool
84 supra (turbo) manual conversion Wed, 27 October 2004 22:55 Go to next message
Hi guys,
I'm bored of my automatic box...would rather a manual...I have a 1985 supra with a manual and a 1984 supra with an auto and I want to do a swap...does anyone know whats involved, do I need to make any modifications?
Oh...plus...the 84 supra has a 7MGTE in it...would the computer start giving me problems if I put in the manual box?
Thanks in advance
[Updated on: Wed, 27 October 2004 22:55]
ZZT231
melbourne.vic.au
Re: 84 supra (turbo) manual conversion Wed, 27 October 2004 23:05 Go to previous messageGo to next message
Do a search on the forum, as it has come up many times.
Also get in contact with Norbie, he converted his car from Auto to Manual though he has a 2JZ-GTE in his.
Cheers.
wilbo666
Re: 84 supra (turbo) manual conversion Wed, 27 October 2004 23:17 Go to previous messageGo to next message
If you have a manual donor car, it should just be an easy swapping affair (gearbox, flywheel, clutch and brake pedals, clutch line, clutch master, clutch slave, gearbox crossmember, tail shaft) Smile Just swap everything and it should be fine, tho I would look at getting an uprated clutch.
I think that the auto 7mgte ecu will be fine (just have to short the neutral start switch from the auto box).
bbaacchhyy
Re: 84 supra (turbo) manual conversion Wed, 27 October 2004 23:47 Go to previous messageGo to next message
The swap itself is not too hard (swapped in a W58 into a Mk2 with 7M-GTE that had an A340E), but a bit of a pain.
Suggested new parts are flywheel bolts ($2 ea from Toyota), new fill and sump plugs for the gearbox and a new rear seal.
I didn't have to bypass the NSBU switch, but then also had to run separate wires to get the reverse lights working, so my luck may be related to the dodgy wiring (the car was bought with the 7M already in) that I have discovered.
I also have the auto ECU.
Here is a pic of my clutch (6 puck sprung centre custom jobbie form Adelaide Clutch) & PP (2000lb Barry Grant modified item)
http://img44.exs.cx/img44/2998/2004-01-26026.jpg
Haven't driven car yet, but clutch doesn't seem to be heavy at all
turbosupra
Liverpool
Re: 84 supra (turbo) manual conversion Thu, 28 October 2004 00:11 Go to previous messageGo to next message
thanks guys...the guy a I bought the spare care from said it had a heavy duty cluth in it so it might come in handy.
turbosupra
Liverpool
Re: 84 supra (turbo) manual conversion Thu, 28 October 2004 00:14 Go to previous messageGo to next message
bbaacchhyy wrote on Thu, 28 October 2004 09:47
Thanks bbaacchhyy...how long did it take you to do it?
Could it be done in 1 day?
bbaacchhyy
Re: 84 supra (turbo) manual conversion Thu, 28 October 2004 00:26 Go to previous messageGo to next message
turbosupra wrote on Thu, 28 October 2004 10:14
It took me longer, but I took my time and didn't have all the parts on me. It would be a long day, but it could be done if you do a bit of prep work.
I'd get the flywheel machined as well, and get a new clutch and get the PP tested as well. Just because someone said it wa HD, doesn't mean it is. If it is from behind a 5M-E, what is HD for that won't be for a 7M-GTE !!!
turbosupra
Liverpool
Re: 84 supra (turbo) manual conversion Thu, 28 October 2004 00:32 Go to previous messageGo to next message
ok..thanks heaps guys...helped alot. I'm on my was to some double clutch and sideways action...haha
negative boost
Hobart, TAS
Re: 84 supra (turbo) manual conversion Thu, 28 October 2004 10:30 Go to previous message
sorry to hi-jack the thread but is there a difference between the 7M Auto ECU and the manual ECU peformance wise?
Previous Topic:1jz hilux
Next Topic:another 1g thread last one
Current Time: Sat Oct 17 03:01:16 UTC 2026
Total time taken to generate the page: 0.0061900615692139 seconds
