Toymods » Tech & Conversions » fual consumption problem in 7M-GTE
muncha
bankstown
fual consumption problem in 7M-GTE Wed, 27 October 2004 23:09 Go to next message
I'm new to this so take it easy on me...plz
I got a big problem in my 7m and dunno where to start looking...for each litre of petrol it will drive 4km...thats shit...a dodge viper uses less petrol...can anyone help?
joorsh
Re: fual consumption problem in 7M-GTE Wed, 27 October 2004 23:12 Go to previous messageGo to next message
Does it smell strongly of petrol anywhere in or around your car at all?
muncha
bankstown
Re: fual consumption problem in 7M-GTE Wed, 27 October 2004 23:20 Go to previous messageGo to next message
Not a strong smell...sometimes it's worse than other times though. SOmetimes I can't smell it at all.
What r u thinking a leak?
turbosupra
Liverpool
Re: fual consumption problem in 7M-GTE Thu, 28 October 2004 01:09 Go to previous messageGo to next message
Please...guys this is killing me...costing me a fortune on petrol...$20 a day thats $140 a week.. Crying or Very Sad
Chris Davey
sunny coast, qld
Re: fual consumption problem in 7M-GTE Thu, 28 October 2004 01:10 Go to previous messageGo to next message
I don't really know but I think if you give more details like mods etc. that may help.
muncha
bankstown
Re: fual consumption problem in 7M-GTE Thu, 28 October 2004 01:12 Go to previous messageGo to next message
No mods at all..just engine conversion from 5me to 7mgte.
Re: fual consumption problem in 7M-GTE Thu, 28 October 2004 02:08 Go to previous messageGo to next message
One of two things are happening:
1. Fuel leak. We can't help you with that one, you'll just have to hunt it down. You should never be able to smell fuel in your car, so if you can there's obviously something amiss.
2. Engine running way way too rich. One clue will be black smoke coming out the tailpipe, especially when you nail it, but to be certain you should put the car on a chassis dyno with a gas analyser up the exhaust and find out exactly what the fuel mixtures are doing under load.
Yian
Lwr Templestowe, Melbourne
Re: fual consumption problem in 7M-GTE Thu, 28 October 2004 02:15 Go to previous messageGo to next message
maybe you got a dodgy O2 sensor? I;ve heard that a dodged sensor can make your engine run pig rich. Just a thought.
Re: fual consumption problem in 7M-GTE Thu, 28 October 2004 02:32 Go to previous messageGo to next message
A dodged O2 sensor would only do that in closed loop. Thats all they do.
Re: fual consumption problem in 7M-GTE Thu, 28 October 2004 02:48 Go to previous messageGo to next message
Yep, and even then it doesn't have a massive impact on fuel economy... it only trims the mixtures by 5% or so.
celicaboy_2000
Lismore, NSW
Re: fual consumption problem in 7M-GTE Thu, 28 October 2004 08:21 Go to previous messageGo to next message
4km a litre I thought mine was bad, pull the spark plugs out and see if they're black "really black in your case" if they look ok you must have a leak some where else. If they are all black check AFM, earthed injector loom, cold start injector leaking etc. If one or two are black probably leaking injectors are your cause... How does the car drive?
joorsh
Re: fual consumption problem in 7M-GTE Thu, 28 October 2004 09:12 Go to previous messageGo to next message
I've heard that bad charcol cannisters can mess with fuel consumption too. Still doesn't explain the fuel smell though.
It's also worth considering that it may not be one single problem - you could potentially have more than one problem with your fuel system.
-J-
bstjunkie
Re: fual consumption problem in 7M-GTE Thu, 28 October 2004 10:22 Go to previous messageGo to next message
Dude has to be a fuel leak, if it was that rich it would flood your plugs and it wouldnt run properly, and u would notice when driving u woudlnt be able to see behind you. You also mentioned you jsut converted it frrom 5mge to 7mgte, so you would hav had to touch the cold start injectors and fuel injectors you can also do a pressure test, but if its that bad you will track it down without one, check your fuel filter too.
[Updated on: Thu, 28 October 2004 10:27]
Danners
Central Coast, NSW
Re: fual consumption problem in 7M-GTE Mon, 01 November 2004 04:55 Go to previous messageGo to next message
Stick it on a dyno and check your exhaust gas readings for ratio? that would basically tell you if you have a leak, or a car running incredibly richly
Dan
Re: fual consumption problem in 7M-GTE Mon, 01 November 2004 05:35 Go to previous messageGo to next message
Isn't that exactly what I said? Is there an echo in here?
Hello-hello-hello-hello....
Danners
Central Coast, NSW
Re: fual consumption problem in 7M-GTE Mon, 01 November 2004 05:36 Go to previous messageGo to next message
well... yes
did i read the whole post? no
my bad Very Happy
muncha
bankstown
Re: fual consumption problem in 7M-GTE Tue, 02 November 2004 10:58 Go to previous messageGo to next message
Thanks guys...I'll have to check the spark plugs next...I know it's not the AFM cause I just changed it...The car still runs really good...it just drinks a lot of petrol...could it be the injectors, would they cause such a problem?
Danners
Central Coast, NSW
Re: fual consumption problem in 7M-GTE Tue, 02 November 2004 21:21 Go to previous message
Usually injectors, if faulty will provide less fuel... not more unless they are told to by a faulty device controlling them
Dan
Previous Topic:96 Celica SX
Next Topic:92es300 Engine Swap ???
Current Time: Thu Oct 29 13:50:01 UTC 2026
Total time taken to generate the page: 0.10505795478821 seconds
