Toymods » Tech & Conversions » What speed does your 4age 20v idle?
gt20v
icon9.gif  What speed does your 4age 20v idle? Thu, 03 October 2002 21:26 Go to next message
I assume OEM ECU would idle it about 600-800rpm, but what about aftermarket ECU? I'm having mine running around 1300rpm, and aren't too happy about it, especially it seems to raise the water temp. so quickly, these couple of weeks the water's always sitting above 90 degrees when I have to stop at few sets of lights! Any solutions?
partyjase
melbourne
Re: What speed does your 4age 20v idle? Fri, 04 October 2002 05:34 Go to previous messageGo to next message
check the radiator fans to make sure they are kicking in, coz even if running higher idle speed the water temp should stay fairly stable cept the fans will kick in more often
jasonp1977
Re: What speed does your 4age 20v idle? Fri, 04 October 2002 10:14 Go to previous messageGo to next message
What direction is your coolant flow to the radiator? is your thermostat working within spec?
gt20v
Re: What speed does your 4age 20v idle? Sun, 06 October 2002 14:04 Go to previous messageGo to next message
partyjase wrote on Fri, 04 October 2002 15:34
I've blown the thermo-switch, so am just turning the fan on at around 90c, how many radiator fans do you use on your radiator? Coz I only have 1 fan running..
gt20v
Re: What speed does your 4age 20v idle? Sun, 06 October 2002 14:06 Go to previous messageGo to next message
jasonp1977 wrote on Fri, 04 October 2002 20:14
I assume it's working because the water in the heater doesn't heat up until it's above 82c, I think the flow is correct, hot water return to the top of the radiator and cold water goes from bottom to the water pump, but I'll check tomorrow to see where the water pump pumps the water to, I hope it's the head (that's correct right?)
gt20v
Re: What speed does your 4age 20v idle? Sun, 06 October 2002 14:11 Go to previous messageGo to next message
So back to the original question, what speed does your 4age 20v idle? Very Happy
jasonp1977
Re: What speed does your 4age 20v idle? Sun, 06 October 2002 22:44 Go to previous messageGo to next message
850rpm
gt20v
Re: What speed does your 4age 20v idle? Mon, 07 October 2002 12:47 Go to previous messageGo to next message
Hi Jason, is that with OEM computer or aftermarket?? If aftermarket, how did you manage to control the idle?
jasonp1977
Re: What speed does your 4age 20v idle? Wed, 09 October 2002 10:29 Go to previous messageGo to next message
oem computer... so I have no idea how you would control it with an aftermarket ecu... the oem ecu controls the idle speed...
gt20v
Re: What speed does your 4age 20v idle? Wed, 09 October 2002 13:49 Go to previous message
I think there's something called Idle Speed Control Valve (ISCV) or something which you probably had connected to your original ECU, I think that's what controls the air leak pass the throttle body, I wonder if that can be controlled somehow by a var-pot or something, coz I assume mine's not connected... (but then I don't know if this "valve" is electronically controlled, or not...)
anyone with a 20v with an after market computer that is idling normally? Razz
Previous Topic:corolla engine conversion
Next Topic:18R 5 speed rbox
Current Time: Sun Nov 22 08:21:39 UTC 2026
Total time taken to generate the page: 0.0055980682373047 seconds
